Results 1 to 10 of 14
Thread: Engine management light and airflow issues following air box de-restriction?
    Regular Member Signumtommy's Avatar
    Mar 2011
    Hampshire
    Default Engine management light and airflow issues following air box de-restriction?
    Hi,
    I de-restricted the air box on my Siggy a couple of weeks ago and ever since I have had an engine management light on the dash.
    Checked the issues and it appears to be an air flow fault.
    I was wondering if anyone else has had similar faults or if this is not related to air box de-restriction.
    Look forward to your responses!
    Tom
    Full Member Big Sig's Avatar
    Have you triedputting it back to see if it clears?
    Regular Member Reevo's Avatar
    Nov 2010
    Leicestershire
    Was the ignition off when you unplugged it?
    Regular Member Knuckle's Avatar
    South
    Youve either unplugged the MAF sensor and forgot to plug it back in, or you have plugged it back in incorrectly.
    Thats the most likely cause anyway no reason for it to affect it at all otherwise.
    alternatively, you may have damaged it during dismantling.
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Have you reset the ecu???
    West
    Quote Originally Posted by Knuckle View Post
    i have never had a pproblem deristricting an air box & there's no need to reset ecu either
    Oct 2007
    Shropshire
    I reackon possibly knocked the air mass meter wires???
    scottish region
    i would also say the plug to the air mass sensor mate
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Probably has another fault like a stuck egr valve or something
    lincolnshire
    to add , done a good few box mods without issues so there's summat else going on bud
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
