Thread: Revs Fluctuating
    Regular Member Wolfie01's Avatar
    Nov 2010
    Wolverhampton
    Default Revs Fluctuating
    Hi All
    The revs on my Vectra 1.8ls (2003) seem to be fluctuating quite a lot recently. In particular when coming to a standstill at a junction, its even cut out once or twice.
    This has only just begun to happen, I changed the plugs, air filter etc over a month ago. Also noticed if I keep my foot flat on the clutch it doesn't seem to fluctuate as much, sign of the clutch going?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    clean out the throttle body and idle control valve with some carb spray fella that uselly helps also when was the last time it was serviced
    Nov 2010
    Wolverhampton
    I've cleaned the throttle body out a few weeks ago, oil change was done around 5 months ago.
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    don't these 1.8 engines suffer coil pack issues like some of the others...
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    Quote Originally Posted by Wolfie01 View Post
    Hi All
    what mileage have you done?
    did you say you have had a look at the coilpack?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    maf sensor possibley
    Jul 2009
    The Rift, Cardiff
    I had the same problem on my 1.8, it turned out to be the egr. It was leaking/sucking air. To check if its sucking spray some carb cleaner on and around it while the engine is running, if it is sucking the idle will fall and almost cut out.
    Could also be an air leak else where.
    Nov 2010
    Wolverhampton
    MAF was replaced when I bought it last year in October. I will look into the coil pack, thanks for the replies.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
  1. 3k revs and thats it.....
    By johnaw in forum Engine & Drivetrain
    Last Post: 11th January 2012, 18:44
  2. revs
    By steelee in forum Vectra C / Signum Troubleshooting
    Last Post: 17th November 2011, 23:02
  3. All revs no go!
    By Princess D in forum Engine & Drivetrain
    Last Post: 2nd November 2010, 00:11
  4. Fluctuating voltage when steering
    By Lao in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2010, 18:44
