Thread: Help with a Corsa C ?? Please !!
    Wales, UK
    Default Help with a Corsa C ?? Please !!
    Had to tow my Grandads Corsa home 0700 this morning. (On the plus side, I got to try out the Vec for towing, no problems whatsoever)
    Anyway, it suddenly cut out. All electrics work, car turns over fine but just does not fire.
    I checked the obvious things, decided I would buy a crank sensor. Anyway, checked the net for location and come across a pedal test to read out he fault code. The fault coded refers to the camshaft position sensor, so happ I was thinking this would solve it but the car still does not fire...
    Any suggestions ? I know its not a vec lol
    Thanks !
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    have you replaced the camshaft sensor?
    Glasgow
    What caused it to breakdown was he driving and what happened? Or did it fail to start after it sitting for a while?
    scotland
    whats the milage ? cambelt snapped ?
    Regular Member Knuckle's Avatar
    South
    Was going to say, cambelt/chain?
    Mine snapped on my Megane 1.6, engine just cut out, no noise or anything like i would have expected. when i tried to start it it just sounded like it couldnt start but was slightly higher pitch/faster where there was no compression.
    Wales, UK
    Yes, cam and crank shaft sensors replaced..
    Quote Originally Posted by byebyeitsagsi View Post
    Driving, when it apparently just cut out. He managed to roll into a bus stop. They said there was no noise, just simply cut out..
    Quote Originally Posted by gsxrster View Post
    Its on about 50,000 2002 yr - never been replaced. 1.2 16v
    Thanks all...
    Quote Originally Posted by Knuckle View Post
    You know what, your all making me think now. It could well be the belt.
    Oh oh..... Ill have to pop the cam cover off in the morning..
    South
    Dont mean to scare you but i was gobsmacked when the AA came and told me it was the cambelt. I expected there to be a big bang if it snaped but it just cut out and wouldnt start back up.
    What engine is it ? the 1.2's have chains so probably would have made a noise.
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    Spanner light flashing?
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
    Wales, UK
    Yer, 1.2 and 16v I believe. You may be right Didnt realise they had chains.
    Quote Originally Posted by Niall83 View Post
    Yes and it shows up crank and camshaft sensor position fault which I imagine would be thrown up for a cambelt failiure.....
    Just off now to whip the camcover off and inspect.
    Cheers all..
    Nov 2009
    Belfast
    On my Corsa C 1.0 12v when that happened it was the spanner light flashing, clock/dials not working and just a ticking when trying to start. Turnned out I needed a new ECU. My was a 2002 model and was a comman fault.
  1. corsa vxr
    By ecotommy in forum The 'Off Topic' room
    Last Post: 22nd February 2011, 19:26
  2. Anyone know anything about Corsa 1.2`s?
    By PeterVV in forum General Chat
    Last Post: 30th January 2009, 21:53
  3. Corsa C Alloy And Corsa D Grille
    By andy.l in forum Parts for sale
    Last Post: 6th May 2007, 12:46
  4. Corsa VXR
    By Madgunner in forum General Chat
    Last Post: 16th March 2007, 00:56
