Thread: Headlamp Lens replacement
    Apr 2011
    Hastings
    Default Headlamp Lens replacement
    Hi
    Can anyone tell me how to change the headlamp lenses (53reg) - mine are coated with the "varnish" caused by years of hitting flies at 80+ on the continent. I've tried plastic polish and many solvents and non seem to have any effect except acetone which dissolves the lens!
    i dont think you can remove them tbh
    Regular Member insignia28's Avatar
    Mar 2011
    Warrenpoint, NI
    You can find various threads about sanding the headlights in the detailing section, is a cheaper option, if you are brave enough.
    How I was told to do it.
    Sand using wetted wet and dry paper, starting with 500 grit, followed by 800, 1000, 1200, 1500, 2000 and finally 2500. Then use a good cutting compound (e.g. Farecla G3) and some sort of electric tool (won't work quite as well by hand), I used a mop attachment and a cordless drill. Then apply polish by hand (e.g. Autoglym paint polish). Worked a treat on mine.
    PM Jezzy, he told me
    New headlights from eBay is probably your best bet mate...
    Quote Originally Posted by gaudonville View Post
    Well, the lens is melted, then sadly it is a new unit
    This would also be an opportunity to fit the darkened one, if only the standard ones are fited, as on the SRI
    You might want to replace both, as the other will be "dimmer" due to the newer one having clean lenses and untarnished reflectors
    I had my nearside fog lamp replaced due to accident damage
    The offisde was slightly dimmer, so had it replaced and corrected the issue
    Amazing how bad it can be after just two years
    Both my front fog lamp lenses are badly scratched, so will need to replaced again
    Regular Member Innes's Avatar
    Plymouth
    Try to restore it first with Wet N' Dry sand paper. Solvents and compounds on their own will hardly touch it. I would start at 800 grit not 500 (unless its REALLY screwed).
    Here was my effort (all done by hand) starting with 800 grit and they were pretty bad. LINKY
    AFTER:
  1. Rear light lens cover replacement
    By pvmoore in forum Vectra C / Signum Troubleshooting
    Last Post: 18th September 2010, 11:23
  2. Vectra C Headlamp bulb replacement
    By mss in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 12:41
  3. headlamp replacement
    By a6lns in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2010, 19:08
  4. recommended headlamp bulb replacement
    By andy.l in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2009, 00:05
  5. Offside Headlamp bulb replacement : SRI bumper, 3.0 V6 CDTI, pre-facelift
    By m8internet in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2009, 11:27
vectra c headlights
vectra c headlight lens removal
vectra c headlight removal
How to remove headlamp glass on Vectra estate
burnt headlight lens on vectra c vectra c front headlights glasshow to remove vectra c headlighthow to remove headlight lens on a vauxhall vectra estatevectra headlight dismountvauxhall vectra c headlightsvectra c headlight glassplastic headlight cover for vectra cvectra c headlight restorationhttps:www.vectra-c.comforumshowthread.php134532-Headlamp-Lens-replacementvectra c headlight lensvectra c removing headlight lensenow to remove headlight cover on a corsa creplace vectra c headlight lensremove vectra c lensessmokey glass inside headlight vectra chow to rebuild headlights vectra creplacing headlight assembly in vauxhall vectra c 2004vauxhall vectra headlightsvauxhall vectra 52 corroded lens headlightvectra c headlight diffuser
