Thread: 1.8 vectra 2002 speedo probs
    MILTON KEYNES
    Default 1.8 vectra 2002 speedo probs
    hi all
    my vectra 1.8 suddenly puts all the speedo and rev dials to zero.it'll also
    lock out the indicators as well as putting the abs light on .this happens mainly when it's cold. everything can be re set by re starting the engine,then its ok.Any one out there had this?
    Incidently if anyone has a problem with the engine cutting to idle on these cars, replace the brake pedal switch and it'll cure it !!
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    check this thread out eddie link
    all those faults point to the C.I.M. module..
    get it in to VX to get it checked, but be ready for a big bill if it has gone.. all the keys will need programming to the module.
    PIMM has just told me he's had to have one fitted.. cost him over 400 quid..
    As far as i know there is no aftermarket solution to this..
    the link to the other thread is how rorycarz fixed his dropping dials..
    SOMERSET
    Quote Originally Posted by Gsi3.2
    Mark is right. It's NOTHING to do with the abs plug behind the battey. I had this problem for 1 month and it got worse every other day.I took the car to the stealers and they plugged her in and it was the C.I.M(control information unit) at fault.
    They fitted the new one which cost £236.00 and charged me £96.00 for the pleasure(i just got my receipt out).
    Since then, no more problems. I will bet you that is defferintly the problem with yours.
    Best of luck
    Heath
    SOMERSET
    That did included a new battery that i needed...
    Sorry H..
    I remembered the figure , but forgot it included the battery..
    MILTON KEYNES
    Thanks all you guys.I discovered this morning that it also puts the lights on by itself .This is a typical computer type malfunction so it's probably this module thingy.I'm getting it to the dealers asap and I'll let you know what happens.
    cheers eddie
    MILTON KEYNES
    Default speedo probs
    took the car to dealers and yes the cim was duff.cost me over £400
    but it's ok now.
    best wishes eddie
  1. Vectra C 2002 Y20DTH Remap DTI 2.0 2002
    By richardkay007 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2012, 14:18
  2. Electrical probs 2.2 sri 2002
    By ratbob in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2010, 18:40
  3. 2002 Vectra Sri 2.2 16v
    By zeadly in forum Cars for sale
    Last Post: 27th September 2007, 21:18
  4. Vectra 2.6 Siemens Sat nav Probs
    By wonga55 in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2007, 22:01
