Thread: maintenance question
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Thumbs up maintenance question
    i'm carrying out a full service tomorrow, cars done 50k, its a 1.8 petrol sri on a 04 plate
    heres a list of what i'm going to do:-
    change oil n filter
    change air filter and pollen filter
    change fuel filter and spark plugs
    fit new aux belt
    change front discs n pads. clean n cheack rear discs n pads.
    apart from greasing the door hinges and locks, is there anything else i should be aware of.
    Glasgow
    Brake fluid change, coolant change. If you want to be really thorough gearbox oil change.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Check the power steering fluid level. Has yours had a timing belt? 6 years or 60k for the 1.8, which ever comes first. Go easy on the fuel filter as it has those silly little push in clips, a small screwdriver can be used or the specific tool is available off ebay for a few quid. Brake fluid is only required if the have not been done within the last 2 years. Coolant change is not part of any service schedule and as long as it passes below -28c it is fine, although the orange/red OAT antifreeze is felt to have a minimum service life of 5 years. Gear box oil is not part of a service and has no change interval either.
    Mar 2011
    llandrindod wells
    chhers mate, got 2 new clips just in case, better safe than sorry, i'm getting the cambelt done soon, might even do it myself if i'm feeling brave.
    how much are recon heads anyway lol, reckon i'll fit a new water pump and thrermostat at the same time along with fresh antifreeze
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    LoL. Thermostat is dead easy and you'll need about 3.5lt of antifreeze to do the change/flush. I never did the water pump when I did mine, will do it next time, if I still have the car.
    Did you get a new rubber gasket ring for the sump plug? 26p from VX I believe.
  1. Car Performance & Maintenance?
    By silver-tongue in forum Petrol Engine related
    Last Post: 2nd February 2010, 00:10
  2. Mouse Maintenance
    By Johnsdutton in forum Comedy & Humour
    Last Post: 20th September 2009, 20:00
  3. cycle maintenance
    By scottyd in forum General Chat
    Last Post: 28th March 2009, 01:13
  4. Well, I went to town with the car maintenance
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2009, 13:38
  5. Air force Maintenance
    By AJA in forum Comedy & Humour
    Last Post: 29th March 2006, 09:35
