Thread: Is blower motor resistor pack same on climate control models?
    Regular Member Partyvan's Avatar
    Oct 2010
    Nottingham M1 J26
    Default Is blower motor resistor pack same on climate control models?
    As title my last Vec C (normal heaters) blew the resistor pack, I swapped it no problem.
    My new Vec C has digital climate control, is it the same procedure, same part etc...?
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    No - and much more expensive to fix
    Glasgow
    As above completly different setup.
    Oct 2010
    Nottingham M1 J26
    Thanks guys. It refuses to blow on any setting, any idea what the problem is?
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    Quote Originally Posted by Partyvan View Post
    sounds like you married her lol well thats what happend to me lol
    Aug 2010
    Luton
    is your carpet wet? has you scuttle drain been cleared? did it stop suddenly
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Quote Originally Posted by markj23 View Post
    Oct 2010
    Nottingham M1 J26
    I noticed the pollen filter isn't sat right, so might be a water leak
    I dont know when it failed, it just refused to work the other day when I turned the blowers on (first time ive tried since owning the car)
    Aug 2010
    Luton
    I would check the scuttle drain the drop the glove box and remove the parts where the resistor is and give a good clean out with contact cleaner
    then try it as this is what someone else did and it worked otherwise its 180 quid
    Oct 2010
    Nottingham M1 J26
    Thanks, i'll give this a try.
    I assume it's 4 or 6 screws to remove glovebox then it's a resistor pack tucked away somewhere? Not sure what im looking for, although I did do this on a non-climate Vec C
  1. Blower Motor Resistor
    By VectraMikey in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2012, 09:23
  2. Blower Resistor pack
    By jammy_c in forum Bodywork & Interior
    Last Post: 16th October 2012, 20:00
  3. HELP! Climate Control Resistor Needed!!!
    By bartsisgod in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2010, 07:34
  4. climate control resistor pack location
    By monkyspunky in forum Vectra C / Signum Troubleshooting
    Last Post: 19th July 2009, 19:19
  5. motor resistor pack
    By timbarny in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2008, 17:17
