Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Bad starting From Warm
    Regular Member viper8's Avatar
    Mar 2011
    Northamptonshire
    Default Bad starting From Warm
    My 2006 Vectra 2.2 Sri Has a Problem
    Starting From Cold ( perfect )
    Starting From Warm And / Or About 2 Hours After .It Has A job To Start
    Tick Over Is Rubbish .Today I Had To Press The Throttle Down To Clear The Lumpy Tickover .
    Something Not Right Somewhere
    Was Told It Could Be Breather Pipes ( Wherever They Are )
    Anybody Got Any Ideas Please
    Full Member tolly's Avatar
    East Midlands
    Trim : SRI
    Engine : 2.2
    Year : 2002
    it could also be the air idle control valve. give that a clean
    Could possibly be the ecu coolant temperature sensor going faulty and keeping the car in cold start mode or a very dirty air filter not letting the engine breathe properly.
    Mar 2011
    Northamptonshire
    checked the air filter today thats ok .and the pipe going to it from the throttle housing .very clean.no dirt in there at all .
    Mar 2011
    Northamptonshire
    Quote Originally Posted by tolly View Post
    where is the air idle control valve ?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    when was the car last serviced
    Mar 2011
    Northamptonshire
    january this year .by vx
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    petrol or diesel?
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    as above, difficulty starting when warm is a symptom of something wrong with temp sensor. Is your temp gauge behaving normally? When I had problems with my CTS the car struggled with warm starts, however, it was obvious there was problem cos temp gauge never moved. Thought it was thermostat first tho, then changed CTS problem solved.
    If your gauge behaves normally, must be something else.
    Mar 2011
    Northamptonshire
    petrol
  1. Warm starting problem
    By sheddy in forum Engine & Drivetrain
    Last Post: 7th January 2013, 22:27
  2. 2.0/2.2 Dti poor starting from warm
    By bigmac in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2012, 19:14
  3. warm starting issues
    By supersteve_75 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th June 2012, 17:55
  4. poor starting when warm
    By ron broughton in forum Engine & Drivetrain
    Last Post: 24th February 2012, 11:40
  5. DTi starting issue when warm (not hot or cold)
    By James24 in forum Engine & Drivetrain
    Last Post: 11th December 2010, 20:28
