Results 1 to 2 of 2
Thread: problem with ABS,brakes & electronic
    Apr 2011
    bury st edmunds
    Default problem with ABS,brakes & electronic
    Hello
    I'm the owner of Vectra 1.8 2003.
    I'v used brakes on the snow and since that time the ABS control light is on and ABS is not working. After some time the speed sensor, cruise control and engine temperature gauge stopped working as well.
    Now, during braking the car strongly 'pulls' to the left.
    After connecting to a computer following errors showed present: P0170 - fuel trim system rich/lean, U2108-C Can Bus no communication with ABS/TC, P0501 speed sensor-range/performance, P0100 Mass or volume air flow circuit high/low input, P1405 Exhaust gas recirculation circuit high/low voltage.
    I'd appreciate any sugestions/comments on what may be the cause and what can I do to remedy it.
    I can deal with many mechanical problems but I'm not great with electronics.
    Thanks for your time. I hope you can help
    Jack
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    First thing to try is to take the ABS module plug off and give it a good clean. It's a known failing point
  1. Problem bleeding brakes
    By pfj in forum Suspension, Wheels & Brakes
    Last Post: 29th August 2011, 19:57
  2. problem with brakes
    By Hideous in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 11:54
  3. Electronic air con (GSi and others)
    By gtr1000 in forum Engine & Drivetrain
    Last Post: 29th July 2008, 19:49
  4. Problem with brakes
    By sri22dti in forum Suspension, Wheels & Brakes
    Last Post: 25th July 2008, 23:03
