Results 1 to 10 of 15
Thread: 2.2 dti limp
    Glasgow
    Default 2.2 dti limp
    Hi guys, unfortunetly today the car lost all power, the engine light came on and she was hunting for idle, no boost at all.
    i plugged in the laptop and it gave a few errors, the fult then went away for about 2 miles, then came back for a split second and solved its self, i then drove 12 miles fault free, turned her off for half hour then back on and the problem was their, turned it off and on again and another 12 miles trouble free..
    the laptop im sure said code p0400 crankshaft speed sensor?
    oh and while this is all happening the rev counter doesnt work,
    Main question: would the EGR being faulty stop the rev counter working?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    P0400 is an EGR fault mate.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    As above p0400 egr malfunction , probably just needs a clean with carburettor cleaner .
    Glasgow
    but would that cause the symptoms i have?
    the other thing i was thinking was surley if the crank sensor was faulty it wouldnt work then not work then work etc?
    im gonna go out and plug it back in and see what happens
    their was other codes though..
    Glasgow
    where is the EGR on the old 2.2 dti? i cant see it? i went and started her their and she seemed fine..
    stored faults where crank sensor no speed or something
    p0400 critical malfunction of some sort, all the little pipes seem to be alright and the vac pumps are working and buzzing away.
    Engine : 2.0DTi
    Mileage : 73350
    Twaiter the egr is at the front of the engine just to the right of the dipstick , it has two coolant pipes going to it
    Regular Member Innes's Avatar
    Plymouth
    Here are the locations of the important bits on the 2.2dti (and 2.0).
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    The EGR on the old 2.2DTI (Vec B) is different. It is vacuum controlled and MUCH cheaper
    Glasgow
    i can tell you my EGR is NOT their! i looked and looked!
    i took her to the garage today but because i cleared the codes they had nothing to go on, but i done 200 miles today and everything seemed fine! so dunno??
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Remove the engine cover and follow the boost pipe (it's at the front). The EGR is vacuum controlled on the old DTI lumps (or so I think lol).
  1. 2.2 dti limp and cut out
    By ptrehearn152 in forum Engine & Drivetrain
    Last Post: 7th January 2013, 23:45
  2. Limp mode help
    By neill in forum Engine & Drivetrain
    Last Post: 20th March 2012, 19:53
  3. Limp mode..
    By ShaunyB23 in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2011, 20:37
  4. DTI limp.
    By madman in forum Engine & Drivetrain
    Last Post: 3rd May 2011, 19:15
  5. It keeps going limp on me!!!
    By Jobbytron in forum Engine & Drivetrain
    Last Post: 2nd February 2008, 20:17
