Thread: Help please if you can
    Apr 2011
    NORTHERN IRELAND
    Thumbs up Help please if you can
    2004 Vectra driver side elec window
    And mirror not wOrking and the central locking doesnt lock the drivers door every other door and boot ok. I have tried fixing it by taking out the switch and cleaning he contacts didn't fix it. Would there be a wire broken. The passenger side window and mirror still work ok from the drivers side switch. Any ideas.... Thanks
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Check the connector that runs into the door from the pillar.
    Apr 2011
    NORTHERN IRELAND
    That Conector plug seems to be ok plugged into door ok. Thanks
    Apr 2011
    NORTHERN IRELAND
    Bump ttt
    Regular Member Das's Avatar
    Turdsville
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Might be worth taking the door card off checking the control module that's secured on the actual door.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds like a DDM fault
    Apr 2011
    NORTHERN IRELAND
    How do you check this module?
    And is ddm the same thing drivers door module?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Yep they are the same thing. Take the multiplug of and give it a clean if it's still not working then a trip to the dealer for tech 2 may be in order
