Results 1 to 10 of 16
Thread: towbar wiring
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default towbar wiring
    is there a plug for the towbar wiring or is it a hard wire job?
    iv just got a almost brand new towbar for 30 quid and it needs fitting
    al.
    Regular Member Craig1985's Avatar
    harwich essex
    I used a relay bypass kit as it came free with towbar and it just scotch locks into back light.
    But you can buy the proper vxl harness that plugs into rear fuse box for £70-£100 irrc?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    sod that.. only paid 30 for the towbar almost brand new..
    im sure someone will come up with the wiring diagram soon
    al.
    If you only want to use a single socket set up you could wire the side lights to the No plate lamp supply and the brake lights to the centre brake light supply(it will have to be that way owing to the way the tail lights and brake lights work) and the indicators to indicator supply on each side.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    TBH if you have bulb failure warning you'd be better off with the genuine vx electrics as it will warn you of blown bulbs on the trailer and disable park pilot if fitted. It's only about 50 quid and saves hacking into wiring
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    i read that rapala but was unsure if it was true..
    i did wonder about the canbus.
    cheers
    al.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    OK..... im going to fit this towbar asap so can anyone point me towards a wiring guide/how2 or anything and il make a detailed how2 my self for here !
    al.
    Aug 2010
    Leeds
    On my Astra i got a kit from towsure in sheffield.
    Be carefull with scoth locks as the vauxhalls have the can bus wiring and joining a wire in can play havoc with it's system.
    You got it for £30 notes im sure you can stump the rest for the dedicated wiring cheaper than a burnt out vectra.
    Regular Member steve19cdti's Avatar
    Nov 2010
    s.wales.bridgend
    hi ive fitte my towbar and used a 7way baypass relay easy to wire up
    Regular Member bobobaldy's Avatar
    Oct 2009
    lanarkshire
    I fitted mine the other day using the 7 way bypass box you can get them on ebay for £13-£30.That deals with the bulb failure problem.Then i just cut in to the brakes the indicators and the side lights.I never bothered with the reverse or fog as its only a small trailor i have .By the way you dont need to take off the bumper as stated on the how to.You can do it with it still on.
  1. Towbar wiring need some help please
    By jel0611 in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2012, 11:37
  2. Towbar wiring
    By Andyc6845 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2011, 17:59
  3. Towbar wiring car has pdc
    By waltz in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2010, 20:11
  4. towbar wiring!!
    By kojak01 in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2009, 16:07
  5. towbar wiring
    By dave t in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2007, 12:09
vectra c towbar wiring
