Results 1 to 10 of 11
Thread: please help guys, or at least give me a clue
    On a Sabbatical mickeystitch's Avatar
    Mar 2007
    peacehaven
    Default please help guys, or at least give me a clue
    Hi guys just taken mine to a local steeler for quick diognostic and he has told me i have two problems still not sure where whistle / siren noise is coming from although it drives fine
    1. he says my belt tentioner the one for the aux belt on drivers side, is braking up , any idea what its likely to cost
    2. he showed me that the turbo pipe gets bigger when you rev it , the big hose on the passenger side and that it has a leak or may be blocked
    wants it back tomorrow to do full diognostic and give me a price.
    what do you guys reckon it is a 120 cdti 77k sri 06-old shape
    give me a clue guys , you have been great in the past
    UPDATE been back outside tinkering and if I pull the little hose off the vachum unit thingy at the front the pipe does not blow up and the whistle stops ??
    When you remove the vacuum pipe you are stopping the the actuator for the turbo waste gate from working and this in turn stops the turbo from kicking in, so I guess that the noise you are hearing normally is coming from a split in the hose and not the belt tensioner.
    Mar 2007
    peacehaven
    Quote Originally Posted by Rapala View Post
    Yeah i think you are right tensioner is makeing a ticking noise, no one seems to mention on here of them failing so i guess they just get noiser and noiser till they annoy you enought to change them.
    So do you think the siren noise is likely to be a split pipe and not the turbo failing again then ??
    Thats hard to say from here but if you get a mate to rev the engine and you listen under the bonnet you should be able to hear where the noise is coming from. It could also be a split in the intercooler itself.
    West
    My aux idler pulley wheel whines a little, i will change this as when...
    Get someone to hold the revs down on boost while you check the boost pipes for the air leak, they do split & any leaks will cause a squealing sound along with excessive smoking due to not enough boost pressure
    Regular Member eaglepva's Avatar
    Up North
    Ive just had my tensioner replaced, cost me £40 for a replacment and £20 this is on the dti tho.
    Mar 2007
    peacehaven
    thanks guys, tensioner sounds cheap enough ( so think I can come off suicide watch for that one )
    Cant for the life of me find the split hose or what ever though, will it muck it up to keep driving it, there is no loss of power and no excessive smoke either ??
    Mar 2007
    peacehaven
    Question
    Right update time, took front off car and rebuilt turbo with kit (was told noise was turbo) well that has made no difference what so ever
    Putt it all back together and whistle is still there, could not see any holes or cracks in intercooler or indeed any split pipes so am at a loss, anyone know of a way of checking pipes/intercooler while in bits as the ****** will not run/rev without being all bolted back together and i am fed up with all the strange looks from next door peeps now
    Mar 2007
    peacehaven
    bump anyone help/advise please
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    my boost pipe expandes before the inlet elbow, (my last pipe) i thnk this is perfectly normal???
  1. Absolutely No Clue
    By scott1102 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2012, 14:13
  2. PC, DVD, TV Haven't got a clue?? HELP!!
    By Bullylad in forum Games Room
    Last Post: 4th September 2009, 13:42
  3. Getting a IO fitted and carphone haven't got a clue!
    By karldower in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2008, 20:42
  4. Anyone have a clue?
    By big O in forum General Chat
    Last Post: 24th September 2006, 18:21
