Thread: Help needed - CD30
    Mar 2011
    Northants
    Default Help needed - CD30
    Hi, Newbie here, both to the forum and to Vauxhalls. Have 06 Signum 1.9CDTI with CD30, which doesnt seem to be working properly. Just wondered if anyone can help. The radio and Cd play ok, but cant change the Bass or Treble. Also the display screen doesn't show radio/Cd info and right steering wheel controls dont seem to work. Any suggestions would be gratefully received.
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    When you say that you can't change the bass and treble,
    Is this because you cannot find the "settings" menu, or
    is the radio ignoring you..
    Regarding the display of information, I am wondering if you have all the connections in your display and head-unit..
    The communications bit are done via the display, so check the wires to the display.
    Pins 19 white and 20 green, are mid-speed communication wires to the head-unit pins 10 white and 9 green.
    (This sends the information to the display)
    Pin 28 green is the low speed communication link to the BCM pin 40 (this receives the control signals from the scroller wheels).
    To me, this points to a faulty display, which is not uncommon on the CD30
    Other than this, try checking the fuses in the end of the dash panel (uk passenger side)
    Fuse 1 = Head-Unit
    Fuses 7 & 9 = BCM (as fitted)
    Fuse 10 = CIM module (steering wheel module)
    Fuse 12 = BCM Overload fuse
    Fuses 17 and 19 = BCM (as fitted)
    Fuse 26 = Display
    and last of all, look at your right scroller control (held onto the right wheel spoke via a single T25 (i think) torx screw..
    See if the little connector is still firmly attached and clean..
    Again - the prime suspect is the Display itself..
    Be aware that you cannot just fit a replacement display... as they need to be divorced and paired as necessary to work..
    Simplest repair of this is to get a pre-married display and head-unit from another Vectra-C or Signum... not any other Vauxhall due to wiring differences etc within the display...
    Mar 2011
    Northants
    Thanks Robsey. The treble and bass thing is the radio ignoring me I think. Also I notice that the buttons on the radio dont light up. The display shows the range etc. but no info on radio settings, I assume it should. Anyway will try the above.
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    The treble and base thing... check your settings..
    Are you set to "USER"...
    if you are set to anything else, then the bass and treble are "pre-set" and cannot be altered. (if this is an option on the CD30.. not had one for several years).
    Regarding the illumination.. the only way that this would happen, is
    a) The lighting "link" is broken between the BCM (pin 40) and the display pin 28..
    However if you have temperature readings, then the wire is intact.
    b) Has the radio itself been out at any time...? If so, the facia plate is attached "electronicly" by a little plug to the radio itself.. plug damaged ??
    c) has the previous owner done a Clumsy LED conversion - gone wrong maybe ??
    It is possible that he may have fried the LED circuit or the PCB... this could also affect the treble / base circuit board.. depending where he fried it...
    If it is either of the last two items, then you need a replacement CD30..
    Now then...
    The CD30 is the same across the Vauxhall range (wiring wise), although the Astra-H and Zafira has a more angular shape (viewed from above).
    If you get a replacement head-unit (radio), then it would need to be totally reset so that it can be reprogrammed to your car..
    An absolute ball ache for the programmer to install from "reset", but unless you can guarantee that the head unit is from a Vectra-C, then there is no other option..
    If it is from a Vectra-C / Signum, then the head-unit can be simply un-paired by virtue of "disable anti-theft protection", a lot less reprogramming to do to install the head unit.
    As said before... by far the easiest repair, is to replace the display and head-unit as a married pair. (no tech 2 required )
  1. Playing iphone through cd30 possible, or parrot kit needed?
    By Jow20 in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2013, 00:40
  2. Fitting Parrot MKi9200- Can it run through CD30 aux?(does CD30 even have aux!?)
    By dibble750 in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2013, 02:20
  3. Quick CD30 to CD30 MP3 question
    By Chip in forum Electrical & ICE (including SatNav)
    Last Post: 24th August 2012, 00:47
  4. CD30 to CD30 MP3 Conversion
    By yysnet in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2010, 00:20
  5. Replacing CD30 with CD30 MP3
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2007, 13:38
cd30 buttons not working
cd30 speed signal
pre setting cd30 mp3 display
zafira b cd30 not lighting up and no display
how to alter basstreble vauxhall cd30
cd30 radio not responding
vauxhall cd30 not working
cd30 radio circuit board
vauxhall cd30 no bass
changing the bass on astra cd30 radio
