Thread: Coding DRL's with Tech2 etc?
    Engine : 1.9 CDTi
    Default Coding DRL's with Tech2 etc?
    I remember someone posting up that they had programed DRL's with Tech2 or somthing like that.
    I have just had a play.
    I had 5 options.
    First was disabled (As factory set) and 4 others.
    Changing them and programming gave me this:
    Version 1: Front side lights only
    Version 2: Front dipped and sides
    Version 3: Nothing?
    Version 4: Nothing?
    The ignition was on (As I was coding) and the light switch was in the off position.
    Oct 2006
    southampton
    15 Post(s)
    Hmmmmmmmmmmm, so, you have tech 2 huh
    Engine : 1.9 CDTi
    I dont but my mate has (Great tool)
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    what version that work depends on your car.. but on some its for autolights, and on ealier models it was for front foglights as DRL.
    Engine : 1.9 CDTi
    Bit more playing and have the following on a full Canbus car:
    Ignition on:
    Version 2: Front dipped lights and side lights
    Version 3: Nothing
    Version 4: Nothing
    Engine running:
    Version 1: Front dipped lights only
    Version 3: Nothing?
    Version 4: Front dipped lights only
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Mine has this: (2007 estate)
    Ignition on:
    Version 1: Front dipped lights and side lights
    Version 2: Front dipped lights and no side lights
    Version 3: Nothing
    Version 4: Front dipped lights and no side lights
    Didnt try with engine running. Always program with swich in position "off".
    I have disable DRL on mine back and front and rewire with two relay so only the fog starts when engine running i position "off". I have also ordered LED`s for my fogs.
    Full Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    I just had the DRL's activated via Tech 2, but I'm not happy with the way they work.
    I selected option n. 4, dipped lights only after the engine starts. This is good, but I have to leave the lights button in position 0.
    If I put it to Auto, then all lights are ON all the time, no matter of exterior light conditions.
    I don't understand what GM engineers were thinking when they made it like this.
    I would have like it to leave the button on Auto and the car to do the rest: only dipped beam in bright daylight and all lights ON when the exterior light goes down.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Got the side lights activated but why Vx design it so that the dips come on when engine is started beats me.
    Apparently you can activate the fog lights but I'm not 100%.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    I have option 1 dipped and side lights. Personally I find the way the auto switch works perfect. It means I dont have to worry about adjusting my interior brightness all the time.
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    The only thing I don't like is that I still have to adjust the button from Auto to 0 and from 0 to Auto.
    It should work only in Auto mode (dipped beam when daylight is present/all lights ON when night comes). Position 0 should turn all lights OFF. At least that's how I want it and that the way it works for other brands (VW, Audi etc.)
  1. More on DRL's
    By Woody in forum Styling
    Last Post: 9th November 2012, 15:57
  2. DRL's
    By sdemps in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2012, 23:55
  3. Drl's
    By montyfert in forum Electrical & ICE (including SatNav)
    Last Post: 10th August 2012, 22:15
  4. electric power steering pump coding tech2 procedure?
    By valvelift in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2012, 09:10
  5. DRL's
    By woodspsx1 in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2011, 22:56
