Results 1 to 10 of 19
Thread: Clutch Pedal Vibration - 150 CDTi
    Oct 2010
    St Neots, CAMBS
    Default Clutch Pedal Vibration - 150 CDTi
    Hi guys,
    Had my SRi 150 Vec for 6 months or so now, and recently it seems to have developed a bit of a vibration coming through the clutch pedal when changing gear. This is mostly 1st - 2nd to be honest.
    Also, when I dip the clutch pedal, it makes a very loud noise, as if the engine noises are amplified. Lastly, the noises coming from the car are very much different depending on if the clutch is up, or depressed..
    After doing a bit of a search about, I am not sure if this is just the way of the VecC, or if it is a tell-tale sign of the DMF giving up the ghost...
    Cheers!
    Sodding Typical on Sea
    Does the noise sound like a tinkling metallic noise can you describe?
    Oct 2010
    St Neots, CAMBS
    Only way I can honestly think to describe it is 'mechanical' and (even more so) like a tractor! I will go have a good listen when I get a chance and describe it while it is fresh in my head..
    Glasgow
    Sounds like the dual mass flywheel (DMF).
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Sounds like the dreadeed DMF problem.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Damn you beat me.
    It does sound like this but hope we can confirm the situation as the DMF is quite distinctive,,
    Oct 2010
    St Neots, CAMBS
    Well, after going out and having a listen, when the clutch is down about 1"-2" the car makes a pulsating, loud almost "err-err-err" kind of sound (look at me being all descriptive). Whereas when the clutch is fully depressed it just sounds a bit 'whirry' and louder than when the clutch is up.
    As annoying as this is, how easy is it to get sorted with NetQ if it is indeed the DMF?
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Any VX Garage will fix it. Do you have a warranty? It is expensive, i think you looking at £600 but dont quote me.
    Oct 2010
    St Neots, CAMBS
    Yea, thankfully I have NetQ!
    This being my first car worth owning with a manufacturer warranty, do I need to go in and state my case, or will they accept it reasonably hassle free? -if it is the DMF that is.
  1. clutch pedal vibration,noisey
    By freelanderbri in forum Engine & Drivetrain
    Last Post: 19th November 2012, 14:30
  2. Clutch pedal vibration
    By Ianz in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2011, 13:41
  3. New clutch and DMF but still vibration in pedal
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 29th September 2011, 16:54
pedal vibration clutch dipped
why is my clutch pedal vibration on my vectrac cdti
clutch pedal vibration vectra cdti
vibration clutch vectra c
