Thread: Changing head light bulb Dip beam
    Regular Member hamish123's Avatar
    norfolk
    Default Changing head light bulb Dip beam
    Hi went out yesterday and warning came on for dip beam bulb driver side .
    Went to change it and all i can do is get the plastic cap off
    Presume you remove the airbox to change it as there is no way my hands can fit in the gap without removing it
    or is there an easier way as so far have found the vec to be a pain in the backside for routine maintenance
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Quote Originally Posted by hamish123 View Post
    Yep...that's it.
    Did mine a few weeks back - both sides in fact.
    It's a 55 reg Facelift Club spec car........didn't find it to bad...The lamps/bulbs are the standard Halogen types...
    Regular Member farley2708's Avatar
    antrim n.ireland
    either remove the airbox or take the front bumper off,only 12 screws & clips holding it on,just fitted HID's,it was a whole lot handier,think you need to be a gynaecologist to get you hand in there,passenger side at least you can lift the battery box lid & remove the washer bottle spout
    them vx mechanics must be able to wallpaper an entrance hall through a letterbox!!!
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    Quote Originally Posted by farley2708 View Post
    na they just take the airbox out like every1 else
    norfolk
    Hi all thanks for info am going to take the airbox off and upgrade the bulds while im at it
    antrim n.ireland
    hi mate,change the dipped to HID's,you wont regret it,i went down the same route as you 1st,put osram N/B in dipped & phillips blue ultra in the main,still not much improvement,got a set of HID's of another member on here...................................wow,unbelie able difference,just needed to add a set of MTEC 501 sidelight bulbs,dont use the main beam now as i have enough from dipped
    11 Post(s)
    Removing the bumper is just as quick. Also less likely to put the ECU fault light on if you forget to connect the air flow meter when finished or testing the HIDs.
    stockport
    Thumbs down
    I found that just removing the top of the air box and moving it,and the ducting,out of the way,gave me enough room to fit the bulb when I changed over to HID's. FELIXX.
  1. Replacing head light bulb
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2012, 11:32
  2. Head light bulb types.
    By Jekyll & Hyde in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2009, 19:27
  3. Changing Fog Light Bulb On Facelift.
    By Hynzy in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2009, 08:40
  4. changing fog light bulb
    By bigben in forum Styling
    Last Post: 15th January 2009, 19:34
  5. Head Light Bulbs Changing
    By tash in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2007, 01:06
vectra c headlight bulb
vectra c dipped beam bulbs
what headlight bulb do i need for vectra c
vauxhall vectea change headlight
opel vectra 2008 how to change beam light
change vectra c dipped bulb 2004changing vectra gsi headlightmain beam bulb vectra c gsi change vauxhall vectra c face-lift awful light on dipped beamhow to remove bulb on vectra c leftvauxhall vectra headlight bulb removalvectra c headlight what bulbheadkight bukb vectra cVectra c dipped beam bulbvectra c headlight removal06 vauxhall vectra club difficulty removing n side headlight bulbheadlight bulb vauxhall vectra drivers side how do i replace low beam bulb 2008 vectra drivers sidevauxhall vectra main beam bulbhow do you change headlight bulb in vectra2008 vectra c dip beam headlamp bulbsvectra c light bupb showingvectra headlight removalhow to change headlight bulb on vectra drivers sidevectra headlight bulb change
