Results 1 to 10 of 26
Thread: Noisey engine when clutch is out and quietens down when its in
    Dec 2010
    Lancashire
    Thumbs up Noisey engine when clutch is out and quietens down when its in
    Hi
    I have a 56 plate vectra 1.9 sri cdti. Its noisey when idling but quietens down when the clutch is in. When you take the clutch out its noisey again.
    Can any one help me please
    exeter
    my brother inlaw had that on his mondeo and it cost him £750 for a new clutch / bearing and dmf because the bearing smashed it up .?
    Dec 2010
    Lancashire
    It seems to drive fine. No problem with setting off or gears. Could it still be the clutch?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    sounds like the central release bearing is u/s,you have to remove gear box to fit new unit ,bearing and central release are one unit.you will need a line up shaft to line up the bearing .
    West
    could well be the dmf on it's way out, does it knock or rattle when cold
    Dec 2010
    Lancashire
    When its cold it seems quieter. Its rattles is louder when the engines warm.
    Glasgow
    It is the dual mass flywheel DMF for short.
    Dec 2010
    Lancashire
    Is it something that needs urgent attension or do i wait till it totally goes? Am assuming its a big expensive job?
    West
    mines on it's way out too lol...
    shop around for prices, the cheapest i have found so far is £550 all in & i will sort it when i get paid this month
    Mar 2011
    essex
    Yeh definately sounds like a dual mass flywheel (DMF). The DMF is a poor design andis a costly component to replace as they recommend changing the starter at the same time due to the clutch and flywheel dust getting into the starter. To get it done its basically gearbox out job, you dnt need to worry about it yet but sooner or later it will need to be replaced
  1. clutch pedal vibration,noisey
    By freelanderbri in forum Engine & Drivetrain
    Last Post: 19th November 2012, 14:30
  2. noisey 2.2 dti engine
    By peadar in forum Diesel Engine related
    Last Post: 7th July 2011, 19:21
  3. Engine Control Clutch Switch
    By 3.2wales in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2009, 21:08
  4. My 55 plate vectra engine sounds alittle noisey then usual
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2009, 22:29
  5. Advice - noisey engine
    By Robbie in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2008, 12:15
