Thread: Good Afternoon All
    Apr 2011
    Fareham
    Default Good Afternoon All
    Hey,
    I have just swapped from an all French arrangement, wife having a 307 HDi and myself having a Citroen C5 HDi. The wifes 307's cam belt snapped writing that off, so I have traded mine against a 2003 Vauxhall Vectra 2.2 DTi Elegance with 65k on the clock. First 7 years of its life was with Lex leasing with FSH, and then a further service by a further 1 owner.
    I am picking the car up tomorrow and want to make sure it is in tip top shape, so I will be doing and Oil, Fuel and Air filter change using Valvoline Engine OilSynpower Fully-Synthetic 5W30 Engine Oil.
    So i have ordered all those parts plus a 36mm socket as I understand that is whats needed for the Oil filter?
    Does anyone know where I can find out the oil capacity?
    Also is there any other maintainence i should consider doing. i.e EGR valve clean, inlet manifold clean, coolant change etc
    Anyway, thanks all for making this forum so informative and I'm sure you'll be seeing a lot more of me.
    Rhys
    New Member Weaselbert's Avatar
    Feb 2011
    Kent
    Welcome
    I'm a bit of a mechanical dunce myself but I'm sure others will be able to answer your questions.
    Apr 2011
    Fareham
    Thankyou, I was beginning to think people were ignoring me
    Sodding Typical on Sea
    Hi mate and welcome to you.
    If you have a manual the capacity will be listed in there sadly mine doesn't have the 2.2DTi listed or I'd have a look for you.
    Regular Member farley2708's Avatar
    antrim n.ireland
    welcome to the forum mate
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Rhys for a 2.2 DTi with a filter change you will probably use about 5.2 litres . depending on how the car has been used worth considering checking the egr , boost sensor/inlet manifold , easy way to determine whether this needs doing is to disconect the hose from the inlet manifold and run a couple of fingers around the inside if you come up with a hand full of Coke then strip and clean all of above gasket,s are reusable on the inlet manifold and egr
    oh and welcome to vec-c and the south central region
    and still loving it
    Regular Member leonvectrac's Avatar
    south shields
    Welcome aboard
    Apr 2011
    Fareham
    Thanks All
    Bob: Yeah I found that it was about 5.5 litres. It seems it's cheaper to pay National Tyres £47 to do the Oil & filter than buy it and fit myself.
    They use Castrol Edge 0w30 and to buy 6 litres of that its about £60 + £10 for the filter and then i'd have to by the 36mm socket for £10 aswell.
    I will be taking a good look on the weekend so will follow your advice.
    I am really enjoying the drive of the Vectra compared to my french cars it is amazing.
    Rhys
    Regular Member Ralphwells1967's Avatar
    dartford
    Hello and to vec c m8
  1. good afternoon to all
    By Slick in forum Introduce yourself.
    Last Post: 22nd March 2009, 15:58
  2. good afternoon all
    By Ribeye in forum Introduce yourself.
    Last Post: 9th March 2009, 22:50
  3. Good Afternoon Vectra-C.com
    By ThurlbySport in forum Introduce yourself.
    Last Post: 13th March 2008, 03:03
  4. good afternoon everyone
    By simon5800 in forum General Chat
    Last Post: 6th June 2007, 18:51
  5. Good Afternoon
    By Orka The Porka in forum Introduce yourself.
    Last Post: 24th October 2006, 21:37
