Thread: Have my Garage used wrong gauge wires on 3rd Inj Mod ?
    Regular Member thefibreguy's Avatar
    bedford
    Default Have my Garage used wrong gauge wires on 3rd Inj Mod ?
    Hi All,
    I have had issues with a strange engine vibration which starts at 70mph. It feels like the car is not firing normally. This started around the same time as I had had my 3rd injector mod carried out by a local garage.
    On looking thru the 'How 2' section, I have noticed that the Yellow 2.5mm leads are recommended, BUT, the chap in the garage has used the Brown 1mm leads!! The Brown lead wire gauge is smaller than the original wire gauge. Could this be a factor? Could this be limiting the current getting to the 3rd injector, causing it to fail at higher speed?
    Any advice?
    Engine : 1.9 CDTi
    Could be.
    The 'kit' vauxhall supply has the right size wire with it.
    bedford
    The kit vx supply has 3 or 4 different wire sizes!!
    May 2007
    Norway
    I used the thickest one from the kit on mine, and works like a charm!
    1mm wire is thin, so perhaps it affects performance?
  1. Boost gauge reading wrong?
    By Steven in forum Troubleshooting
    Last Post: 11th March 2012, 12:11
  2. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  3. Wrong place wrong time.
    By silverhairedracer in forum General Chat
    Last Post: 29th October 2008, 14:20
  4. Replies: 2
    Last Post: 15th September 2008, 23:18
