Results 1 to 10 of 21
Thread: Testing EGR solenoid!!
    Regular Member thefibreguy's Avatar
    bedford
    Default Testing EGR solenoid!!
    Guys,
    Can the solenoid be checked by just popping into a 12v supply?
    Cheers.
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    yes
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    It will move quickly though, as I think the valve operates on 5V but I'm 100%, but I know it's not 12V.
    Gazza4
    Aug 2009
    north east
    So being a complete biff how would you do it? What do you use?
    thanks Max
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by maximus8425 View Post
    thanks Max
    Buy a 240-12V DC pack, it should have the option to turn it down to about 5V. Connect across the pins. That's how I would do it. Tbh If the car is having low down torque problems, the solenoid won't be the problem, as a spring returns the valve closed. If the valve has jammed open or is jamming open then the engine will be down on power and less responsive. If it is closed the car will be more responsive and have it's factory power output, however the emissions light will come on.
    Gazza4
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    id make sure its not a stepper motor first or putting dc to it will do nothing.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Al 22 dti View Post
    Just a solenoid on the CDTI's, I personally think testing it is a waste tbh.
    Gazza4
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    oh right.... so fully open or fully closed lol
    not exactly the best way to control a hot gas id say.
    al.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    al.
    You said it.
    Gazza4
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    i wonder if the ecu pulses it to control flow?
  1. Actuator Solenoid
    By chris_gsi23 in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2012, 18:15
  2. Cleaned EGR + Solenoid - now as new
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2012, 20:23
  3. VXR 2.8T Engine solenoid what does it do?
    By Damo in forum Engine & Drivetrain
    Last Post: 2nd October 2010, 23:13
  4. lubricating egr solenoid
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2010, 17:09
  5. How about solenoid valves!?
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2006, 17:51
vectra c egr solenoid
