Thread: Inlet manifold gunk, Will '10K Boost' shift ?
    Regular Member thefibreguy's Avatar
    bedford
    Default Inlet manifold gunk, Will '10K Boost' shift ?
    Guys,
    Got the EGR off, it ha been cleaned recently, & the valve moves freely. BUT, I did notice that the inlet manifold side is solid with gunk!!!. I scrapped it out gently with a screwdriver, god knows what the inside of my manifold looks like. Will a dose of '10K Boost' help clean the inside of the manifold? Car has done 48k miles.
    Regards,
    PS just also cleaned Boost sensor, it was also gunked to the max!!!
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    be very careful scraping the gunk out incase you leave any lumps behind as they get sucked into the cylinders and can cause valves to not seat properly.
    al.
    Regular Member Mopar Man's Avatar
    herts
    Yes it will help. Look on how 2.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    I wouldn't advise trying to clean out the manifold with 10k boost, its good for light soiling but what you can see in the end of your manifold is only a FRACTION of the thick gunk.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by the-wizard View Post
    You will have to remove the throttle body and physically remove the gunk from the entrance to the manfiold. Tbh at the best of times I'm dubious about spraying these cleaning agents into my manfiold. A good few on here have tried it however with good results.
    Gazza4
  1. Replies: 15
    Last Post: 3rd July 2012, 21:14
  2. Inlet manifold gone
    By clightowler in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 22:40
  3. Inlet manifold what do I need
    By sebadee in forum Engine & Drivetrain
    Last Post: 6th March 2011, 00:41
  4. inlet manifold
    By redross555 in forum Engine & Drivetrain
    Last Post: 13th February 2011, 14:52
  5. Going To Fix My Inlet Manifold!
    By corderz in forum Engine & Drivetrain
    Last Post: 12th February 2011, 09:29
