Results 1 to 10 of 11
Thread: brake problems please help
    Sep 2010
    prestatyn
    Default brake problems please help
    hi all,
    i have a vectra 3.2 elite 53 reg 04 registered and i have just tried to do the rear brakes pads, but cant get the piston back in to refit the pads, anyhow i have just read the how to and wish i had read it before i started the job because i now have a car on the axle stands with no means of getting out to buy the piston rewind tool, does any body have a link so i can buy the correct tool online and solve my problem.
    thanks in advance steve.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    i once saw a socket that was ground down at the top to include two points that fit in the holes to fit if that helps?.
    al.
    Sep 2010
    prestatyn
    Regular Member Mopar Man's Avatar
    herts
    If your really stuck and cant wait?
    Try using a gee clamp and a pair of mole grips. You've got to push the piston at the same time, turning it clockwise.
    Be careful not to chew the boot, just grip the edge of the piston. If you where closer, i would lend you the tool.
    Sep 2010
    prestatyn
    hi, thanks for the reply i just had a go with some grips but its just chewing the edge up so going get the correct tool, which one should i buy and are the ones in my last post any good if so which should i buy?
    thanks steve.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    the first link above is the one I have its very good however if you intend to move away from vauxhall you should look at other kits
    Full Member Big Sig's Avatar
    I know its possible to push and turn them back in with a pair of long nose pliers.
    Gävle, Sweden
    Managed to do this rather easy with a clamp and a pair of pliers, so it's definately possible to do without the special tool.
    exeter
    iused thin nose pliers and it worked fine
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    yep every time long nosed pliers and a bit of pressure
  1. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  2. Asbestos use/c;utch brake problems
    By eirevectra in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2010, 19:04
  3. Brake problems, Bleeding, Warped Disc?
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 24th December 2009, 13:56
  4. Veccy brake problems
    By toughmat in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd June 2009, 16:41
  5. Veccy brake problems
    By toughmat in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2009, 19:49
