Results 1 to 10 of 11
Thread: 1.9 cdti 150 auto vibrations above 70mph !!
    Regular Member thefibreguy's Avatar
    bedford
    StatsVehicle Info
    Default 1.9 cdti 150 auto vibrations above 70mph !!
    Hi All,
    Over the last few weeks I have noticed that as I drive above 70mph, I get a slight, but very noticeable vibration coming thru my pedal. The only way I can describe it is that it feels like the car is running on 3.5 cylinders!!
    About the same time I started feeling this, I had just had the 3rd injector mod, egr clean, & a new flexi downpipe fitted.
    Just to eliminate the obvious, I had my front wheels rebalanced today, but still feeling vibes.
    The car pulls like a rocket from start, & the auto box seems like it is ok. The problems seem to start at 70mph!!.
    The garage where I had the work done checked for faults (not tech2), but non recorded.
    Any ideas?
    Regards.
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    StatsVehicle Info
    is it just through the pedal you feel it?
    bedford
    StatsVehicle Info
    Not just the pedal. I can feel it thru the car, but it comes up thru pedal.
    Sodding Typical on Sea
    StatsVehicle Info
    The pedal and steering wheel are both pretty connected to the chassis so any irregular running will be felt in these plus the gluteus maximus (AKA the Ar5e) so it is a good indicator of irregular running.
    My money is still on the EGR i have to say despite the cleaning it could have solenoid issues,,,
    Mar 2011
    Donegal
    StatsVehicle Info
    you coud have a bent rim or a bad tyre also.
    Regular Member Mopar Man's Avatar
    herts
    StatsVehicle Info
    Got to have a look at a 2.2 Manual tomorrow, with a similar problem.
    I told him i will check his inner CV joints first.
    Mar 2011
    Donegal
    StatsVehicle Info
    track rod ends can cause this problem to if the bushing is worn on it.
    bedford
    StatsVehicle Info
    Thanks for the 3 above, I did have my wheels rebalanced, but did not think of looking elsewhere on the suspension etc.
    I would think its an engine problem, but she accelerates like a lambo (!!), but problem starts at 70mph ish!! There is a alignment/suspension specialist in town, will book in with him to check out suspension.
    bedford
    StatsVehicle Info
    Quote Originally Posted by Mopar Man View Post
    Please PM me if you sort out.
    Cheers.
    bedford
    StatsVehicle Info
    Sorted the problem .
    Its amazing really. I was getting the vibe from the front end, but on inspection, my garage discovered this
    What had happened is that a crack in my wheel, had deflated the rear o/s tyre. The tyre was flat, & me being a t@@t, didnt notice for a couple of days, its only a 35 profile so hard to tell at the best of times!!. When I did finally notice, & pumped it up, the damage had already been done to the inner walls. I did not notice because it was on the inner face!!
    So, when I took the car over 70mph (on a private road !!) I got a very noticeable vibe from the front, which was actually coming from the rear!!!. I was thinking all sorts, screwed auto box, duff injector etc,etc.
    The final bill - £250 for a pair of Falken 235/35/19's, £25 to weld wheel, £30 fitting etc. The car is now back to her old self, flying along, eating miles like nobodys business!!
    Thanks for all help.
  1. vibrations
    By tiimi in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2012, 17:55
  2. Vibrations?
    By Exclusive BV in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2011, 15:40
  3. 2.8 & 3.2 auto V6 revs @ 70mph
    By i320 in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2009, 00:44
  4. Estimates of 30-70mph time for a 3.0 CDTi running a CRD2 box?
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2007, 13:14
  5. CDTI RPM at 70Mph in 6th gear
    By Mr_Me in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2006, 19:47
astra cdti automatic vibration
