Results 1 to 10 of 21
Thread: Sump Plug Spinning!!!!
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default Sump Plug Spinning!!!!
    Hey all,
    Having a bad day anyway, then this happens.... Doing an oil change on the 2.2DTi, the sump plug went back in easily, and then carries on spinning ie not tightening up. I did not cross thread it at all, and no issues getting it off either. Stuck my finger in the hole of the sump and it seems like there's a threaded "col-let" or something that's loose. Even when the plug is screwed 95% of the way it you can rock it side to side. So currently got the car stuck in my back garden with no oil in it
    What's my best bet to have it fixed? I can't fill it up to drive it anywhere. We do have a fabrication deptment at work, so if i could get the sump off maybe the guy at work could fix it, is removing the sump an easy job? And would Vauxhall stock a new sump gasket (it looks as if I've had bit of a leak anyway).
    HELP SOMEONE!!!
    East Midlands
    Try some ptfe tape on it.
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by macdad View Post
    That plumbers tape?? Would that be a decent enough fix as although I do 20,000miles a year, I am looking to get rid this summer...
    Engine : 1.9 CDTi
    If its the bolt thats spinning in the thread it should be but not if the thread is loose in the hole.
    Glasgow
    Sounds like its been overtightend and the thread on the sump Is fubared. The only fix for it is a new sump I'm afraid.
    Full Member Big Sig's Avatar
    If your 100% getting rid and you don't mind being really rough, weld it in
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by byebyeitsagsi View Post
    ARGH! So is there nothing I can do if I whip it off and see what's going on??
    Full Member
    South West
    Helicoil perhaps? Not sure if one could be applied to a sump.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    it may have been helicoiled in the past and the coil has been damaged,remove sump and have it rethreded oversize,or as BB says replace sump
    Engine : 1.9 CDTi
    Not true anymore.
    You can buy sump thread repair 'kits'
    We have used them a few times at the garage I work at when they have been damaged before.
    You tap the next size up (Ie M16 to a M17) and fit the slightly larger sump plug.
    Anyone know what size it is?
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Sump plug
    By nokiaman1978 in forum Engine & Drivetrain
    Last Post: 8th May 2012, 20:46
  3. Sump Plug
    By Tam80 in forum Engine & Drivetrain
    Last Post: 13th February 2011, 18:55
  4. sump plug
    By luke.oldham in forum Engine & Drivetrain
    Last Post: 7th January 2011, 22:33
  5. Sump plug
    By Daywalker in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2009, 19:48
