Thread: Can I ............
    Regular Member installer's Avatar
    Nottingham
    Default Can I ............
    ........... remove the MAF sensor on a 1.9 CDTi to clean it and not cause a problem requiring Tech 2 to reset?
    The car isn`t going to be driven with the sensor removed.
    providing you do it with the car turned off..i.e. no key in the ignition.. then yes..
    don not touch the maf sensor's internals at all..only use a spray cleaner and allow to fully dry before re connecting..
    if the car is turned off, then there should be no probs..
    Leicester
    You should be OK doing as GSi3.2 has suggested, but can I ask why?
    Are you suffering from bad running?
    Nottingham
    ta very much
    Got my self 1 ltr tub of Isopropyl Alcohol and a sealed bag.So going to slosh it in ther for a few min.Didn`t think a spray would be much cop.
    Not going to nothing to the car while it`s not connected - the MAF that is
    Nottingham
    Quote Originally Posted by Matt
    Follwing on from this thread i looked at my MAF best I could and you could see residual stuff on it.
    So I`ve took out the K/N and replaced with new standard filter.Had to buy entire new air box to get a new lid,cos I`d chopped off the tube leading to the MAF.At least came with a new filter.
    Have had poor running a hesitation on constant/light throttle while sat at continuous speed.Vxl have updated my ECU and it`s been fine since.But I plan to keep this car a while and don`t want any premature failures for the sake of 1 or 2 bhp.
    Leicester
    Thats fair enough then, do you not recomend the K&N die to this. I have just installed on in the Audi and have one on order for the Vectra.
    I have never had any issues with K&N panel filters but do like to here if people have.
    Nottingham
    I`ve courteny panel filters before never a K/N and did have a conversation about air filters with John but can`t remember the conclusion properly.
    Seeds of doubt have been placed in my mind.Unless it can be proven they give significant benefit,I`m going to replace the vxl one every 6 months
    with oil and filter change.
    Still keeping the K/N with modded air box lid.Still got the bottom section taken out of the box though.
    Regular Member ion's Avatar
    walsall
    This is why I kept the original filter.
    It's amazing how much stuff it collects in there, a small percentage getting through would be very bad IMO.
    Not worth it for a small gain.
