Results 1 to 10 of 23
Thread: 1 problem sorted and 1 more problem arises
    Regular Member bunsen1's Avatar
    suffolk
    Default 1 problem sorted and 1 more problem arises
    finally sorted the fuel filter ( fingers crossed) so for convenience i thought i would just go to a garage to get my oil changed and filter with parts supplied, but the sump plug is rounded off completely
    what can i do? guy at garage said he could chizel it as he done it before but if it cracks the sump i have been warned, so i left there needing a sump plug which will have to grab monday but is there any other way of getting this out without risking cracking the sump?
    not sure what to do??????????????
    any advice please
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Not the first person to come accross this issue, he should be able to remove it by knocking it round with a chisel, its either that or go buy a Suction pump and remove the oil through the dipstick tube. These really do work(look them up on youtube), youll never have to lie under a car again to do an oil change.
    http://www.screwfix.com/p/laser-oil-...xtractor/21663
    Regular Member Craig1985's Avatar
    harwich essex
    I knocked a 1/2 inch hex socket over it as it's a tight fit and it worked fine. Another thing you would try is a decent pair of moleys (pliers that clamp tight)
    Regular Member Mads's Avatar
    Ipswich,.UK
    mine was rounded off too and i couldnt get the fuel filter out of the canister so i took it to vx with my own parts and they charged me £53.00, they also plug tool in as i had eml on sometimes and advised me i needed glow plugs and control relay (which im going to do myself) and also the front 2 suspension springs had broken ends.... so worth the £53.00 imo
    hope you get it sorted
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    http://cgi.ebay.co.uk/Jabsco-Puppy-1...#ht_1026wt_907
    iv got one of these knocking about.... think il drag it out for my next oil change.
    al
    suffolk
    wish i had the money for those links guys, its just the bit about the damaging of the sump that worrys me
    "mads" its the sump plug thats rounded off mate,
    dasarab- are these really that good then? probably cost me say £10 just geussing for sump plug and £35 for them to do it
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by bunsen1 View Post
    http://cgi.ebay.co.uk/Oil-scavenge-p...ht_3227wt_1141
    cheap enough?
    al.
    harwich essex
    Just use a 1/2 inch hex socket it's free and will take you jo more than 10 min yo loosen off. Let the engine run for a few mins to get it warm also helps
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    They work really well apparently. A lot of people seem to worry that the dont take all the oil out or leave crud behind, but you can swivel the end around to get the last drops out and the filter is designed to filter out the crud anyway.
    http://www.youtube.com/watch?v=CYPH3...feature=fvwrel
    http://www.youtube.com/watch?v=su5kYzAyFt4
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    now i like that!.
    il deffo be rigging my pump up to an old oil can for deffo on my next oil change
    al.
  1. First problem sorted
    By mat6028 in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2011, 18:43
  2. hesitation/missfire problem sorted
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 10th June 2011, 08:51
  3. Update on recent egr problem (now sorted)
    By kamar in forum Engine & Drivetrain
    Last Post: 26th August 2010, 07:31
  4. emision light problem sorted
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2009, 12:53
  5. Wiper Problem Finally Sorted
    By Mowster in forum Vectra C / Signum Troubleshooting
    Last Post: 31st March 2009, 13:30
vectra c using hex sump plug www.vectra-c.com
