Thread: Knocking coming from rear
    Sep 2010
    bolton
    Default Knocking coming from rear
    I have a 2006 vectra sri and I am getting a knocking thats coming from rear. Took it into garage and he checked all the bushes including arb and said there was some play but not enough to make the knocking noise. He could here the knocking noise when he test drove it and said if it was one of the bushes he tested it should be ready to fall off. Any ideas
    I'll go for a rear shock absorber
    Wearing soft gloves (so as not to damage the paint) lift each side, listen for a squeek noise
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    did you check the exhaust?
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    i had this problem last week and checked all the bushes with the car in the air could not find any play with the weight of the wheels then tried it with a bar and the car on ramps turned out to be the banana shaped bar bushes that come from the center to the top of the hubs replaced them both now spot on ,the rear was a bit twitchy over bumps as well and it has sorted that out
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Quote Originally Posted by simreg View Post
    Chech your rear upper control arms. To do this, with the car on the ground and not jacked up. Take both hands and place inside wheel arch and hold on to the top of the tyre.
    Try pulling and pushing the wheel towards you and away from you. There shouldnt be any movement.
    If there is, you should hear a clonking noise and this will be the problem .
    Upper control arms are quite dear and very awkward to replace.
    Selby
    rear shockers im guessing mate, one of mine decided to explode on me and now becuse there aint any fluid inside it knocks and bangs like hell, still deciding on what set up to go for but by the sounds, BILSTEIN B4 and lowering springs is the way to go?
    Regular Member csd_19's Avatar
    Oct 2006
    Aberdeen
    Engine : 2.8T
    Quote Originally Posted by Graham View Post
    Currently £35.74 each from LMF
  1. rear knocking
    By tommy tess in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2015, 21:23
  2. Knocking noise when coming to a stop
    By preecy in forum Suspension, Wheels & Brakes
    Last Post: 4th December 2012, 21:54
  3. Knocking from the rear?
    By Steven in forum Suspension, Wheels & Brakes
    Last Post: 8th November 2012, 22:49
  4. Knocking on rear
    By richy1974 in forum Suspension, Wheels & Brakes
    Last Post: 18th October 2012, 15:59
  5. Knocking coming from front of the car!
    By Deano-vec in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2009, 22:03
