Results 1 to 3 of 3
Thread: coolant flush, and gearbox oil 2.2dti help
    Regular Member paul.sessions's Avatar
    leighton buzzard
    rolleyes coolant flush, and gearbox oil 2.2dti help
    right think im going to attempt this 2moro, but not sure where to start, could some one guide me through full coolant flush/change. and gearbox oil on a 2.2dti too please.. and how much i will need?
    tia Paul
    Regular Member Mads's Avatar
    Ipswich,.UK
    hi mate when i changed my water pump i needed 3.75 litres of coolant, to empty the coolant on my 1.9 cdti there is a tap that you turn on the bottom of the radiator as for the gear box oil i havent done that yet.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Gearbox oil is a right sod. The drain plug is RIGHT next to a chasis rail or part of the subframe if I remember right. Had to cut the tool bit in half to get it in. Fills ok through the reverse light switch. 1.9 litres of fluid and a tube of Molyslip in mine.
  1. coolant flush
    By antowens in forum Engine & Drivetrain
    Last Post: 14th December 2012, 13:26
  2. coolant flush
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2012, 20:30
  3. Oil cooler replacement & Coolant Flush query
    By kon123 in forum Engine & Drivetrain
    Last Post: 29th September 2009, 19:47
  4. Flush or No Flush(2.2Dti)
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 20:35
2.2 dti gearbox oil
zafira a 2.2 dti gearbox oil
