Thread: Pedal Trim Removal
    Regular Member vectrasimonsri's Avatar
    Dec 2010
    OXFORD
    Default Pedal Trim Removal
    Hello all, I am sure someone knows how to do this?
    I am trying to remove the piece of plastic trim from around the pedals to allow me to remove the brake and clutch pedal sensor. In the old Vectra this was quite easy, a few plastic supports and you simply pop it out gently.
    I have removed the three obvious torx screws, but nothing has moved or seem like it wants to come out. The only other way I can see it comes apart is to remove the lower plastic part from underneath the steering column, but then thats joined to the headlamp switch . I am normally handy with trim and panels so I feel a bit stupid now!
    Dec 2010
    OXFORD
    btt
    Dec 2010
    OXFORD
    has nobody done this before when changing or a brake pedal sensor?
    Dec 2010
    OXFORD
    Ok, maybe now I need a crowbar and hammer, still can't remove and there are now no screws securing the trim. If this is how well they build the vectras these days I will remove all spare screws to lighten the car!
  1. Accelerator Pedal Removal?
    By OPC in forum Styling
    Last Post: 16th June 2010, 13:39
  2. Interior trim removal.
    By mally in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 00:25
  3. a piller trim removal
    By lloyd_456 in forum General Chat
    Last Post: 1st September 2009, 20:26
  4. Trim removal
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2007, 14:45
  5. Trim Removal
    By SJG in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2005, 23:12
