Results 1 to 10 of 13
Thread: Polishing wheels?
    Norwich
    Trim : SXi
    Engine : 2.2
    Default Polishing wheels?
    What do you guys use to clean your wheels? Do any of you use polish or a wax?
    Got a new set of wheels and waxed them as I find they are easier to keep clean but wondering what everyone else does?
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    I Used Megs Ultimate Compound And Then Nxt Generation 2.0 Wax On Mines Other Day...
    Come Up Good Considering They Are Needin A Re-Furb
    Shows Up The Kerbing More Now lol
    Norwich
    Trim : SXi
    Engine : 2.2
    Quote Originally Posted by Tam80 View Post
    I'd hate to do it to the wheels I have on at the mo they would look like they have been chewed over by a shredder
    Regular Member Dennisd's Avatar
    Oct 2010
    Netherlands
    Trim : Sport
    Engine : 1.9dth
    Mileage : 92000
    If you want to remove little scratches (swirls) you can polish them, before you wax them. I use lake country cones for polishing, with various polishing produckts (depends on the amount of scratches) my wheels. But after that i wax them and i use either collinite 845 or wheelwax for it. The collinite is a long lasting strong wax which is also used in the industrie to wax powerlines.
    For cleaning wheels i would recommend carpo iron.x and and a strong alloy cleaner such as Poorboys world spray&rinse.
    Regular Member mcwharam's Avatar
    Oct 2007
    Leeds
    Just done mine today, all wheels off, scrubbed inside and out with a strong APC and then treated with Poorboys wheel sealant. I put 4 coats on over about 3 hours. Then each wash I put another layer of Poorboys sealent on. Do a major clean once every 6 months, insides usually takes some AG tar remover to get the crud off.
    Afterwards when washing most of the wheel gunk will come off with a hose / power washer.
    Mar 2011
    Cleveland uk
    Clay bar work very well too
    Norwich
    Trim : SXi
    Engine : 2.2
    collinite 845 is some good stuff forgot about that cheers!
    mcwharam.....man thats dedication!
    Mileage : 000
    Planet Polish wheel sealent, is one of the products I use.
    Mileage : 000
    I find that there are not any real good wheel wax/sealents that last, due to the heat from the brakes.
    I find that cleaning the wheels on a regular basis is as good as anything.
    Regular Member Reevo's Avatar
    Nov 2010
    Leicestershire
    Thought about using T-Cut on the inside of rims for there first ever "wheels off" clean, any problems with doing that?
  1. da polishing
    By vinty firth in forum Northern Ireland (RO - Vacant)
    Last Post: 26th July 2012, 11:15
  2. Polishing Kit
    By martin_SRI in forum Detailing and Car Care Discussion
    Last Post: 22nd August 2011, 23:08
  3. polishing
    By rave5 in forum Detailing and Car Care Discussion
    Last Post: 26th September 2009, 23:34
  4. car polishing
    By happypostie in forum Detailing and Car Care Discussion
    Last Post: 13th February 2009, 18:40
  5. polishing
    By vectragsi3.2 in forum Detailing and Car Care Discussion
    Last Post: 6th June 2008, 17:13
