Thread: strange braking issue...
    Regular Member hagga's Avatar
    kingswinford
    Default strange braking issue...
    On the way home tonight going a lil quicker than I should had to jump on the brakes a little.. as normal brakes bit nicely and scrubbed off loads of speed...came off the pedal then back on and pedal was hard to depress and felt that braking efficiency was crap.. came to a stop..restarted off and everything felt ok again???? I've got 360mm 6pots up front/325mm 4 pots rear, red stuff pads, braided hoses and dot5.1 fluid so fade/boiling brake fluid shouldn't be an issue (though not really symptoms of fade).. any ideas?
    Chelmsford
    Sounds like a vacuum issue...
    You checked the vacuum hose for leaks/blockages?
    kingswinford
    vac seems to ok.. tried it again tonight and it was ok..hmmm funny one.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    if you stamp on the brakes realy hard, the servo gets emptied of its vacuum and takes a little while to vac back up.
    it happens on older cars usually
    al.
  1. Strange issue??
    By JamesGTB in forum Engine & Drivetrain
    Last Post: 13th June 2012, 11:26
  2. Strange creak when braking?
    By Dazzy2006 in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2011, 23:17
  3. Strange braking problem, any idea's?
    By barney490 in forum Suspension, Wheels & Brakes
    Last Post: 16th September 2010, 16:12
  4. Strange noise after heavy braking
    By oilslick in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2010, 12:05
  5. Strange sensation under braking
    By dolf.peeters in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2010, 11:47
