Results 1 to 10 of 26
Thread: V6 3.0 CDTI has a mental breakdown
    Default V6 3.0 CDTI has a mental breakdown
    My car has been quite smokey recently, only noticeable when passing through 2500 - 3500 rpm with the gas on full
    Last night joining the M73 whilst the engine was cold (still warming up), got up to 50mph and noticed a sudden complete loss of power
    Looked down to see the Engine warning light on
    Clearly the engine had gone into safe mode
    Looked behind to see an ENORMOUS cloud of black smoke which had clearly been produced by my car
    Changed up to fourth gear and kept pace with a HGV, leaving Motorway at next exit
    Pulled off the Motorway, then switched the engine off
    Waited 30 seconds, warning still on
    Waited 3 minutes, warning still on
    Waited 5 minutes, all clear
    Took it easy, back on to the Motorway
    However no smoke at all
    Once engine temperature was up to 92'C gave it some beans, recreating the same technique I had used to join the M73 previously, and no problems at all
    Sadly didn't have the "pedal test" script with me
    Parked the car up last night, so tried today, nothing
    Looks like some gunk had become trapped, and had then been thrown through the fuel system, the engine having a complete mental breakdown
    I suspect this is what ruined the previous SCVs
    Went for another run, again no smoke
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Get the codes read. We might know more then.
    At first I thought it might be a busted intercooler, but then you say the fault didn't come back after the restart...As I said, get the codes read, then we might know whether the fault is fuel or air related.
    Quote Originally Posted by Celes View Post
    As above, did the pedal test this morning, nothing
    Went to dealership (free diagnostic as car was serviced within last four weeks, but had to wait three hours) this afternoon, also nothing
    However, they reckon as it has been 24 hours and the car has been started about 12 times it has probably been deleted
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    There should be even if the fault is not present.
    The EMS can only hold so many starts
    Equally, when I tested the faults by disconnecting the MAF, after 20 restarts the previously recorded fault is deleted and the dealership had demonstrated this to me
    The same issue occured the first time with the blocked SCV
    As I had restarted the engine over 20 times, the stored code had been deleted
    However, the second time it occured I drove straight there and left the engine running, but it returned "Unknown fault"
    Not too bothered by this one, as whatever it was has blown out the back end!
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    You started the car up 20 times in the space of 24 hours? Very unlikely.
    Other than the smoke out of the back did you notice any other symptoms?
    Yes, as had completed three starts on leaving the Motorway, and one more on re-entering
    A further two before getting home
    Some light use this morning, so that is a further six starts
    The pedal test had then been about a further six
    Taking the car to work was three, then taking the car to dealership was one, and they started it, so that is another one
    Engine wise, nothing
    The smoke has been increasing, but at last months service they advised it was nothing compared to some they had seen (not sure as mine is one of only three Y30DTs they regularly see)
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I find this very annoying. My Y30DT likes to puff black smoke under acceleration, but I've no idea why. Previous owner put a new turbo before he traded the car in, I replaced the injectors with new ones, EGR is ok,...
    Do you have any idea what might be causing "our" smoke problems?
    Just had me thinking about that
    Ran outside, so it was a cold start
    Listened to the engine and it has lost a metallic rattle it has had for some time, sounds more like it did a long time ago
    I put this down to "age and mileage"
    At the service they put this down to "age of the injectors on that mileage"
    I am wondering if the new fuel filter has trapped something, some old junk has crept past at the service, and that is what pushed all the junk past the fuel pump (which would previously have been trapped by the SCV)
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    This noise? http://www.youtube.com/watch?v=mP8f6idrDBw
    My mate from Germany suggested it could be worn aux belt pulleys, which apparently have to be inspected when replacing the aux belt (80k I think, 120k km).
    Mine is always quiet as a mouse when cold, but when it's hot...well you have the vid...
    At the service they say age of the injectors, but why does mine smoke then when I have just replaced the injectors with NEW ones?
  1. Mental 2 weeks!
    By Mr Hyde in forum General Chat
    Last Post: 13th July 2011, 23:04
  2. Mental
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2011, 15:45
  3. mental trike.....
    By david.aka.judas in forum General Chat
    Last Post: 21st May 2010, 07:05
  4. Mental drifting
    By mark1319 in forum Comedy & Humour
    Last Post: 12th August 2007, 22:36
