Results 1 to 10 of 14
Thread: air-con not cold
    Feb 2011
    eastbourne
    Default air-con not cold
    It's getting warmer and I noticed my 57 plate 1.9 (150) A/C wont blow cold air. I was hoping as it's done a load of miles that it's never had a re-gas. So at my work I attempted to re-gas,there was no gas in the system and it would not hold a vacuum which means it must have a leak somewhere.
    So does anybody know if there are any weak points on the A/C system ie condensor-evaperator or certain pipes?
    Regular Member degsy1234's Avatar
    Jan 2010
    Here
    Just got mine back from the dealers. Had a new condensor fitted under warranty
    Feb 2011
    eastbourne
    Quote Originally Posted by degsy1234 View Post
    Do you know what the fault was with the condensor?
    Full Member Big Sig's Avatar
    I'd imagine it had a hole
    Feb 2011
    eastbourne
    I assume it wasn't stone hole as it would not be warranty. Is there a potential weak point on the condensor?
    Jan 2010
    Here
    sorry didnt ask what the problem was.. Was just glad when they said it was covered under warranty
    Feb 2011
    eastbourne
    I would be too
    Quote Originally Posted by tights View Post
    That all depends on the person inspecting the car and what they pit in the report.
    Feb 2011
    eastbourne
    Yes that "could" be the case, that is why I asked. What I'm asking if anybody has a sensible answer is is there any weak points on the A/C on these to save time looking?
    Regular Member BIG-G's Avatar
    Oct 2009
    thurso
    check the bottom drivers side of the radiator.
    as mine was rotten and it had leaked all the gas out.
    i put up pic's of the radiator on here.
    just had it fixed under warranty
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  3. So you think it is cold here.
    By ed taylor in forum General Chat
    Last Post: 23rd December 2009, 15:36
  4. No Cold Air
    By dhwigston in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2009, 18:52
  5. A cold one.
    By shan in forum General Chat
    Last Post: 10th September 2007, 00:40
