Results 1 to 10 of 14
Thread: Chirping Wastegate...
    spoons
    Guest
    Default Chirping Wastegate...
    I've heard cars in the past with dump valves that make a pshhhht sort of sound when changing gear.
    Its a matter of preference and personal taste, but I'd rather not have one as the repetition would wear me down.
    I've heard rally cars with chirping wastegates as well, which I thought sounded a bit different and was always lead to believe that Vectra VXR's dont have either... as it recirculates the pressure (or whatever lol).
    Anyways, since my Stage III upgrade.. when the car is all warmed up and racing to the red line, I've heard my wastegate make that chirping noise on gear changes..
    Doesnt happen all the time, but its quite good
    Never had that before
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    i love the sound of it ill hear it on sunday lol
    Regular Member Marcosuk's Avatar
    Fife
    If i speed up in say 2nd then come off the power, i usually get turbo chatter if theres not enough pressure for the re-circ to dump... Sounds pretty good imo
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    i have it on mine in each gear, I am not sure i like it.. Its louder if you have a cone filter type induction system fitted..
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Yup same here, my 2.0T has always done it in every gear if I accelerate reasonably hard.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    I had the same in my old 2.0T. Don't hear it in my diesel though.....sort of miss it
    Regular Member benny's Avatar
    Feb 2006
    dudley
    rallly cars have a seperate wastegate / actuator in the lower part of the system .. most road turbo's have a built in wastegate / actuator so your never gonna get the rally sound ...but with upped boost and a few tweeks agreat sound can be had ....
    this is a rally car style waste gate ......a mother of a wastegate ....lol ...http://en.wikipedia.org/wiki/File:Turboexternalgate.jpg
    normal road going diesel wastegate ......http://en.wikipedia.org/wiki/File:Internalgate_vf39.jpg
    also vvt ones ......http://en.wikipedia.org/wiki/File:Va...tryTurbo_1.JPG
    all really a variation on a theme ...plus you got actuator types and loads more ......
    Sodding Typical on Sea
    The noise comes from venting the excess boost to atmosphere, and was a constant source of debate when I drove Saabs as the ones fitted with early emissions would accept an atmos dump valve but later cars, the ones using an OBD2 diagnostic system (so cars basically made from 98/99 on measure the air volume as well as the quality so when you vent the pressurised system out it loses air that it has calculated as combustible volume and throws teddy out the pram.
    Now,,,, there is a dump valve from Forge I think that is a dual action so does domp back into the low pressure intake stream as well as a little to atmos via the trumpet, so gives a lovely blow by sound for those so inclined,,,,,,
    Regular Member iainm9438's Avatar
    Dec 2010
    Gloucester UK
    when i had the 'chirping' on my sapphire cosworth (stage 3), i was told that it was the noise made by the turbo stalling whilst trying to vent the excess boost. apparently it isn't good for the turbo unless it is uprated with stronger bearings etc.
    how true this is i don't know but as i said it was what i was told?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by iainm9438 View Post
    thats true.. and its called turbo compressor surge.
    when the turbo it at full boost and you come off the throttle, the compressed air has no where to go and it backs up and forces its way back passed the turbine blades and makes the chirp and that slows the turbo down very rapidly and yes its not good for the turbo at all as it makes it spin off its axis and puts a lot of access pressure on the bearings.
    thats why they dump the pressure off.
  1. Help with Chirping Noise
    By rossc1976 in forum Engine & Drivetrain
    Last Post: 13th October 2012, 16:36
  2. Chirping alternator belt
    By signumkev in forum Engine & Drivetrain
    Last Post: 31st May 2012, 15:32
  3. Chirping noise CDTI please help
    By ONEMINUTESILENCE in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2011, 19:47
  4. chirping noise
    By leesri in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2011, 20:38
  5. chirping heater fan
    By Morephun in forum Bodywork & Interior
    Last Post: 30th December 2010, 18:55
chirping wastegate
