Results 1 to 3 of 3
Thread: 1.8 VVTi Oil Light
    Oct 2007
    Ripon
    Default 1.8 VVTi Oil Light
    Just asking how long it takes for the oil light on your vvti to go out on first start?
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    Mine takes like 2-3 seconds.
    Oct 2007
    Shropshire
    A second or two after start up. It does take ages. HOWEVER I checked the pressure and it shoots up straight away. I think the sensor just takes a lot of pressure to turn it off. Fit a lower pressure sensor from the old non vvt 1.8 and it will fix the problem....
    Basically its the light taking ages rather than the oil pressure....
    If you think about it. If the sensor takes 30psi to activate instead of 20psi for example then it takes longer to get up to 30psi than 20psi so it takes longer to go out!
  1. What is meant by 1.8 VVTI? is the vvti engine better or worse?
    By Deann in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2011, 11:19
  2. 1.8 vvti Oil Light & Rattles
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2011, 13:53
  3. 1.8 VVTi MPG
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2010, 11:33
  4. 1.8 VVTI More HP????
    By krd0707 in forum Petrol Engine related
    Last Post: 23rd December 2009, 23:38
  5. 1.8 vvti sri - mpg
    By gangleyshag in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2009, 11:30
