Results 1 to 10 of 11
Thread: 2.2dti vacuum pump leak
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default 2.2dti vacuum pump leak
    hi.. it looks like iv got a leak from the back of the vac pump.
    is it an easy job?
    regards
    al.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    oil leak i might add lol.
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    just a couple of bolts i think on the vac pump?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    no idea.
    been told its just an o-ring but also been told its a gasket that leaks.
    al.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    does anyone know if its a gasket or a rubber o ring that i haver to replace to stop the oil leak at the back of the vac pump on a vec c 2.2 dti?
    al.
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    what is the vac pump al?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    sorry davey, its the vacuum pump for the brake servo and other stuff located on the right hand side of the cam on a 2.2 tdi.
    mine seems to be leaking from there down the block.
    al.
    Mar 2011
    Donegal
    yes i get you now, seen it today when i was out at the car, thanks man
    reason i asked is because im trying to get my car sorted at the mo. cheers
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    does ANYONE know if its an o-ring that seals the vacuum pump onto the end of the camshaft?
    someone must know?
    al.
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    Will look into it...
    edit. Looked into it, its a sealing ring...
    redit. 4 bolts hold it on not 2 as I first thought...
  1. vacuum pump cdti
    By mon in forum Engine & Drivetrain
    Last Post: 23rd January 2013, 09:31
  2. vacuum pump leak... :(
    By geleziux in forum Vectra C / Signum Troubleshooting
    Last Post: 25th May 2011, 21:22
  3. 2.2DTi Y22DTR vacuum hoses scheme
    By Zemi in forum Engine & Drivetrain
    Last Post: 5th October 2010, 15:45
  4. vacuum pump
    By Dougb in forum Engine & Drivetrain
    Last Post: 30th June 2010, 22:41
  5. EML - Vacuum Pump ?
    By matiny2k in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2008, 20:53
2.2 dti vacuum pump
2.2 dti vacum pump leak
2.2 dti vacum pump oil leak
vacuum pump 2.2 dti
vectra c 1.9cdti vacuum pump leak
opel vectra c 2.2 dti vacuum pump
2.2 dti leaking oil vacuum
