Thread: deadlocked car
    Default deadlocked car
    i know this may not be able to be answered on here as it could help thieving toerags get into your car but....
    is there anyway to undo a deadlock on a car
    i ask because the car breaker that just had the signum in near my work , the car is deadlocked and im sick and tired of climbing in and out of the broken drivers window to try and get bits off it !!!
    its justa query about this and if the thread has to be removed i totally understand
    South West
    Try sending the car a text message mate... I hear that this works!
    aidi thats quality
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Wonders If Car Will Txt U Back
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
    Quote Originally Posted by Aidi View Post
    11 Post(s)
    Quote Originally Posted by marktaylor View Post
    Angle grind through the door where it latches to the B post.
    Regular Member davidmcd2002's Avatar
    Feb 2011
    Nottingham
    take the reg number down, apply for a log book and order a set of new keys from VX main dealers. Or replace the locks with new ones.
    Jul 2009
    The Rift, Cardiff
    unless you get a key/transponder coded to the car it can't be done. Not even a sonic screwdriver can bypass a deadlock.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Being a fellow man of The Corps, you would just use your spare key that you keep safely squirreled away for just such an occasion, obviously.
  1. Deadlocked Signum
    By t13con in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2009, 19:46
