Thread: Ticking and loss of everything :( HELP
    Nov 2010
    scunthorpe
    Default Ticking and loss of everything :( HELP
    Well here goes guys.
    Had my 1.8 05 vectra sri for about 7 months and its been spot on jump strating various cars and really reliable in the cold crappy weather etc.
    went out last night in it and parked up like normal and locked the car. All fine.
    Went back to it this morning and pressed the boot button, the boot unlocked and i opened it and put something in it. Then shut the boot and pressed the door unlock button - NOTHING.
    Tried a few more times and still nothing so opened with the physical key and could hear a ticking noise from the back fuse box and maybe the front fuse box too?
    Manually unlocked all of the doors (pulled the catch up) and all of them open but the front passanger. Even the boot button wont work now. When i put the key in and try to start it - the ticking stops but it doesnt even attempt to fire up.
    Im thinking maybe front passanger actuator or something ? took boot fuses 17 / 18 / 21 out and they all seem ok but the ticking wont stop and the door wont open or start. Ive now at work (LATE) and have left the battery off in the hope something will reset itself over the next 5 hours.
    Any advice on this as its even strategically parked in underground parking down a hill so recovery is going to be a pain in the a***.
    Ill have a crack at most things and im not all clued up but im not completely daft?
    HELP
    New battery time me thinks ..............Vec batteries will just die for no reason, no warnings or anything !!!
    Nov 2010
    scunthorpe
    Quote Originally Posted by Drinky View Post
    Its been a strong old battery but why would all of the other doors unlock and not the front passanger and why would both fuse boxs be ticking - relay maybe?
    Regional Organiser - East Region whiskyno7's Avatar
    norwich
    19 Post(s)
    Vehicle : vauxhall signum
    Trim : 2.0t
    Engine : chipped and remapped
    Year : 03
    Mileage : 100k+
    i spent 4 hours pulling my car apart. because it wouldn't start. it turned out to be the battery worked night before dead by morning
    it say's it all
    Nov 2010
    scunthorpe
    Quote Originally Posted by whiskyno7 View Post
    son of a gun lol. should still jump start though lol
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    yes will jump start
    classic vauxhall battery
    Nov 2010
    scunthorpe
    Quote Originally Posted by markj23 View Post
    yes will jump start
    guessing the clicking is the alarm then and the door just hasnt got the power to unlock lol. best bit it is in undergorund parking tight into a corner haha got to manouever it out backwards to jump start it lol - ill borrow my friends bmw 330i
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    If there is ticking from front and rear, then I am going to go off at a tangent...
    The doors are controlled by the REC and BCM
    The REC is controlled by the Body Control Module (BCM)
    It is not uncommon for the BCM to "Tick", where a faulty relay is to blame..
    So check all your relays and fuses in the body control module
    (End of dash fuse panel)
    Then check the REC (Rear Electrical Centre) - Boot fusebox and all connectors..
    Regarding pulling the battery, then this does indeed sort about 90% of electrical glitches that Vectra-C suffer from when they get a cob-on..
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Sounds like battery to me, VX batteries tend to just give up without warning. Get the battery checked but 97% certain its the battery
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    Try jump starting it of another car and that will tell you if its the battery. If it starts then its your battery if it doesn't then its not the battery.
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
  1. Ticking 2.8 v6 auto and loss of power when driven hard
    By chunkey_monkee in forum Engine & Drivetrain
    Last Post: 13th February 2013, 23:25
  2. ticking noise when air con on.
    By philc1210 in forum Engine & Drivetrain
    Last Post: 30th July 2011, 20:42
  3. Odd ticking noise
    By Big Sig in forum Engine & Drivetrain
    Last Post: 20th June 2009, 22:54
  4. Ticking noise
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2007, 19:08
  5. Ticking
    By jimsoft in forum Bodywork & Interior
    Last Post: 3rd September 2007, 22:25
