Results 1 to 3 of 3
Thread: Exhaust flexi on 1.8 petrol...
    Chelmsford
    Default Exhaust flexi on 1.8 petrol...
    Did my backbox a couple of weeks ago and it was a bit of a pain to get off...
    Having seen a post on here about flexi pipes, started thinking that I've probably strained mine quite a bit (it was already split slightly at both ends)
    Is the flexi simple enough to replace on my car? Or is it an expensive pain in the backside like it was on the Vec B (downpipes, flexi and cat, all in one part)
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    The flexi mesh bit seems to separate quite easily, mine is like this and think Leonvectra posted pictures showing his the same lately, but as long as it is not leaking inside it your exhaust is still ok. You can get a replacement flexi part that welds in to the original pipe but unless you have a welder at home your probably just as well just having the whole front pipe replaced. However........ I have never ever seen a front pipe unbolt without first being heated up with the aid of a gas torch, they are usually a complete PITA to do and normally best left to a garage to do.
    Regular Member leonvectrac's Avatar
    south shields
    Heres mine below, still is ok and not blowing so is being left till a later date.
  1. EXHAUST flexi pipe
    By sparky1292 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2012, 15:08
  2. exhaust flexi blowing
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2012, 11:02
  3. Split exhaust flexi
    By Jasond in forum Engine & Drivetrain
    Last Post: 12th January 2012, 23:47
  4. Flexi Exhaust Pipe
    By SarahP in forum Vectra C / Signum Troubleshooting
    Last Post: 1st January 2012, 20:14
  5. Exhaust flexi size.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2010, 21:30
