Thread: Front Fogs Keep Fusing!!!
    Regular Member KeeronMac's Avatar
    Mar 2011
    Donegal
    Default Front Fogs Keep Fusing!!!
    Hi guys, like the title says my front fog lights keep fusing, specifically the passenger side one. I haven't changed the drivers side one ever!! I've checked and its sealed fine, no water or anything getting in, maybe a faulty wire or something??? Any ideas???
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    If it is blowing the fuse, then the wire must have chaffed, allowing it's inner conductor to short out to chassis earth.
    Or further up the wiring, there maybe water getting into a connector.
    But this is unlikely as the weather has been fine and dry recently.
    I would trace the wiring back from the fog-light, towards the big connector on the left side of the radiator grille (near the bottom edge)..
    It also carries the wires for the temperature sensor /sender..
    This wire then continues in two directions..
    The temp sensor wires head towards the rear of the engine bay (left side) and has blue and blue/white wires.
    The foglight wires should head towards the centre of the engine bay (under the main fuse box) into the underhood electrical centre..
    Chances are that water could be getting into the big connector near the grille, or less likely, one of the big connectors underneath the engine bay fuse box.
    Mar 2011
    Donegal
    Thanks Robsey, I'll check that out when I get a chance and let you know how I get on.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    You're welcome...
    Note it is a standard understanding that Left is the near-side of the vehicle (or UK passenger side)
    Otherwords left is as viewed by the driver when seated and looking forward.
    So - the connector is low down, on the same side of the radiator grille, as the winscreen washer spout and the battery...
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    He's in God's Country. Co. Donegal. The left side is the same here in Ireland. I had the same problem with my Corsa C, never got down to the problem before I sold it a few weeks ago. Hope you can sort it.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Ah - I've never been to Northern Ireland nor Eire, so couldn't be certain as to which side you drive on... hence why I quoted UK passenger side..
    Nothing worse though to be facing the front of your car and looking back over the bonnet and saying... "Robsey said the left side" and not finding anything, because you are looking to your left and not the car's..
    Aren't All countries God's country... because he is Omni Present...!!
    Nov 2009
    Belfast
    We're just that little bit special tucked away in the North West of Éire
    Mar 2011
    Donegal
    I'll let you guys know soon, its not even the fact that it fuses all the time (although that is quite annoying) its more the fact that its always flashing on the dash Got a lot of work on this week but I'm taking Wednesday off so I can check a few things out then.
    Mar 2011
    Donegal
    Checked all the connectors and wiring, seems fine, fog lamp bone dry. I figured that i have been getting faulty lights?? New light on now, see how long it lasts, thanks for the help.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by KeeronMac View Post
    Yup, keep us informed how you go on..
  1. 06 2.2 sri front fogs
    By 06sri in forum Bodywork & Interior
    Last Post: 18th June 2012, 19:49
  2. Front fogs
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2010, 00:20
  3. front fogs
    By cbl1985 in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2010, 19:10
  4. front fogs
    By derby4life in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2007, 09:55
  5. Front fogs
    By fishphone in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2007, 12:56
