Thread: strange headlight fault
    Jan 2010
    Scotland
    Default strange headlight fault
    have a 2006 elite non xenon that keeps giving me a headlight bulb out warning
    sure enough i have a look and the bulbs out.
    pop the cover (passenger side) and give the connector a push and it comes back on no problem leave the cover off (which is not touching the bulb or wiring in any way and it will be fine for days. put the cover on and its fine until you turn the car off and start it again. when the bulb will go out and you have to give the connector a nudge.
    also found this one side is eating bulbs (i've put 3 in the spce of a month whearas i've not changed a single bulb on the rest of the car in 6 months
    any thoughts on this guys? its really starting to annoy me now
    11 Post(s)
    Have you tried cleaning the connector contacts instead of just giving it a nudge every now and again?
    If you're frequently having to change bulbs, that could be a sign of low voltage - caused by dirty connections (also referred to as a high resistance joint). Does the glass of the blown bulbs look darkened or have a chrome appearance?
    Jan 2010
    Scotland
    will give that a bash Dave
    cheers for the heads up
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    BTW, did you touch the bulb glass with your hand? Should carefully wipe it clean with a mint free cloths.
    Quote Originally Posted by yysnet View Post
    Why? How does mint effect the glass??
    11 Post(s)
    Finger grease on bulbs is really only an issue on halogen headlight bulbs. Wipe off with something like iso prop alcohol or meths.
    Shouldn't cause any problems with indicator, reverse, tail, side, or brake light bulbs.
    ps, you are only meant to use mint free cloths on VW Polos.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    mint lolol
  1. Headlight keeps going out...Very strange
    By shammon in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2012, 08:40
  2. Strange Headlight Pattern
    By hothatch in forum Electrical & ICE (including SatNav)
    Last Post: 14th November 2011, 16:57
  3. strange headlight thing tonight
    By circushead in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2011, 04:15
  4. Strange Wiper Fault
    By lightfx in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2010, 13:47
  5. Strange fault
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2009, 15:52
faulty headlight bulb keeps going off vectra cdti
headlight keeps going off vectra cdti
vauxhall signum headlight fault
