Results 1 to 10 of 14
Thread: Alot of questions... help/advice please..Very long
    Regular Member Mads's Avatar
    Ipswich,.UK
    Default Alot of questions... help/advice please..Very long
    Ive not long had my 55 reg vectra 1.9 cdti sri 150 and i wanted to give her the once over. after i fitted a new cambelt kit, water pump, v belt, pollen filter, air filter, done the egr,boost and throotle clean i took the car into vauxhall today to get the oil and fuel filter done with the last of the parts i brought as i couldnt get fuel filter out of canister and the sump plug was rounded off which they done, but then come the dreaded news that both the front spings were broken and the eml light was on so they checked that..... turns out i need 4 x glow plugs and a control unit too, all in all for vx to do this inc parts and labour/ vat they wanted £534.87p
    i signed a disclaimer and took the car back as it was only 2 miles to ponder over what to do, ive had 3 vectras in the past and they all have broke a spring or 2 as this is a very common fault with them. i thought i would have a look on ebay and came across these http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT i offered the seller £75.00 plus postage (vx wanted £177.16 + vat for front set) which they accepted so im chuffed and think its a good price, also my vxr spoiler turned up in metro blue so the day got better.
    so i have a few questions.........
    1.there was 2 springs 001 and 002 but they both said for the 1.9 cdti so im hoping the ones i got are correct?
    2.will i need these 13178464 sleeves 4 or 8 of if any?
    3. how easy is it to fit the springs yourself, do i need any compression tool, ive got to buy i torque wrench as i think its 90lb on the nuts?
    4.does make of glow plugs make any difference, any recommendations?
    5.does anyone know where you can buy tiger seal for the vxr spoiler or will evo stick do or something else, i know ebay but i want it for the weekend any tips on fitting?
    many thanks if youve read all this any tips/suggestions/comments welcome
    Full Member paul.sessions's Avatar
    leighton buzzard
    i got tiger seal on ebay very good stuff it is too
    make sure the springs are sri ones as they are lower, get two sleeves for the bottom of the spring on the fronts. easy to do springs you will need compression for the front springs but not the rear.
    Ipswich,.UK
    Quote Originally Posted by paul.sessions View Post
    how will i get the compression for fronts mate?? do i need a tool, or have you a link for one if so
    leighton buzzard
    http://cgi.ebay.co.uk/HILKA-2X-SPRIN...item19bea3a456
    these are the same as what i used bit better than the single claw ones
    Ipswich,.UK
    thanks for the link, is that the right part number for the sleeves for the eibach springs i just bought on ebay and how many sleeves in total do i need?
    leighton buzzard
    2 sleeves is all you need for the front springs you dont need for the back
    leighton buzzard
    13178463 front sping sleeves
    13178464 rear spring sleeves if you want them
    good thread here to check http://www.vectra-c.com/forum/showth...light=13178463
    Ipswich,.UK
    thanks i spose it wont hurt to get back ones too? just looking at halfords etc to see if i can get the compression tool tomorrow as the one on ebay i doubt will be here for the weekend
    Ipswich,.UK
    Ipswich,.UK
    any other thoughts on others question?
  1. Seems alot of road noise
    By Angel1368 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 09:46
  2. Alot of oil around injector 1 and 2
    By b7a55y in forum Engine & Drivetrain
    Last Post: 13th March 2012, 16:51
  3. alot more mpg from non supermarket fuel.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2011, 17:22
  4. Guys, advice, warn you tho its a long one
    By Vectralicker in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2011, 20:55
  5. not alot on ebay for vectra c
    By pogo in forum General Chat
    Last Post: 23rd September 2006, 05:36
