Thread: faulty injectors
    Regular Member plawrie123's Avatar
    Jul 2010
    fife
    Default faulty injectors
    have a problem need help car wouldnt start got towed to garage they called and said all four injectors were gone so need replaced the car goes for a second and then stops geting quoted 750 pound to fix help
    Regular Member benny's Avatar
    Feb 2006
    dudley
    did they say what was wrong with them ? ...
    Jul 2010
    fife
    Default injectors
    no they didnt say just that 4 would need replacing
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
    you can get recon injectors of ebay for £80/90 .that price seems abit steep to me
    Jul 2010
    fife
    Default injectors
    is it likely that 4 will go at the same time though
    Cardiff
    Yeah that seems abit much! i would get a 2nd quote
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by Dharm View Post
    It's a bargain compared to what I was quoted for 6 injectors for a V6CDTi. £5000 all in
    Regular Member Kev_G's Avatar
    Jul 2009
    C:\Uk\Chester_North West
    as ive said before on here a friend cleans and re seals injectors with a 24hour turn around -
    here is the thread - http://www.migweb.co.uk/forums/items...g-testing.html
    Alot cheaper and it will tell you if you have a issue or not
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    I replaced my injectors the other day,it was still a bit lumpy on tick over when cold,so i unplugged the egr valve and have blanked it off,and it tick's a lot better now,i don't think it will ever be 100%,as i was also told it is to do with the alternator and common rail signal/power feed ?
    Regular Member Mopar Man's Avatar
    herts
    I would fit the modified injector wiring loom first.
    If one is getting a bad feed, then it can cause the engine not to run.
    It can back up a fuel lock in the common rail system.
    Look on HOW 2
  1. injectors
    By sandy13 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th January 2012, 13:12
  2. Checking for faulty injectors
    By lofty in forum Engine & Drivetrain
    Last Post: 24th June 2011, 10:05
  3. injectors
    By damo-SRI-T in forum Petrol Engine related
    Last Post: 9th June 2011, 08:02
  4. Replies: 3
    Last Post: 20th September 2007, 21:34
