Thread: Droning noise from front - not bearing
    Regular Member Marc 100's Avatar
    Nov 2005
    Berks
    Default Droning noise from front - not bearing
    Hi all. Couple of weeks ago started getting a droning resonance from the front of the car that increased with road speed from about 40-50 mph. Was also occasionally feeling it via a very slight buzzing through the accelerator pedal.
    Car has now done 97k so suspected wheel bearing. Jacked front up and there was some play in driver's side wheel but not passenger side so ordered a new bearing from LMF.
    Got new bearing fitted today but the noise is still there!
    Tyres all have plenty of tread and are wearing evenly. Wheels don't get hot so wouldn't appear to be brake related.
    Tried putting space saver spare on to check it wasn't the wheel but noise was still there and kicked in even earlier at around 30 mph.
    Any ideas please?
    Regular Member simmo3187's Avatar
    Jul 2010
    North Wales/North West Border
    Engine : 3.0 V6 CDTI
    won't it just be the tyre profile on certain surfaces?
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    Try moving front wheels to back and see if the sound follows to the rear. my Tyres droned at the rear so moved to the front and droning now at the front and I get vibration in steering wheel now, Tyres are only half way into there life so will put up with it for now.
    Nov 2005
    Berks
    Thanks for the replies.
    Don't think it's the tyres. On my fourth pair of NCT5s on the front now and never had this before. Current pair have only been on 7k.
    Jan 2008
    Irthlingborough
    If the tracking or the camber or tow has been knocked out this will make the tyre wear uneven, might be worth it for 10 mins of your time.
  1. Droning noise from the front offside
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2011, 22:22
  2. Droning noise
    By HHH in forum Engine & Drivetrain
    Last Post: 18th June 2010, 20:36
  3. rubbing noise/droning ?
    By bigmac in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2010, 10:54
  4. droning noise when reversing
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 16th March 2009, 08:52
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
vectra drone offside front
