Thread: Wheel bearing issue
    Regular Member Pete B's Avatar
    Malvern
    Default Wheel bearing issue
    I have a noise from the front N/S (06 reg 1.9CDTi Estate) and it seems like the hub bearing assembly is on the way out. It is noisy even by jacking up & spinning the wheel and the usual checks (trapped debris round the disc etc) revealed nothing.
    I've got the bearing ready to fit along with the 3 hub retaining bolts and drive shaft nut (all part of the genuine FAG kit), total cost of £87.50 + p&p.
    Reading the Haynes manual before starting, I see that the various other bolts & associated nuts i.e. lower arm to hub, hub to strut and caliper mounting are recommended for replacement on reassembly.
    Are these bolts all torque/angled once only to yield and therefore cannot be reused safely?
    Just wondering what others did when replacing wheel bearings before going out and buying all these extras. I couldn't find anything specifically referring to replacement in the forums.
    Thanks in advance.
    Don't bother buying new bolts/nuts just use a little thread lock and make sure they are tightened FT ........I have changed countless suspension/bearings on Vec C's and never ever had an issue.
    what drinky said , they only say that so you spend money on stuff you dont need
    Malvern
    Thanks for the replies.
    Also made a quick check with the local Vauxhall dealer, the mechanics never change the bolts when doing the bearing hub unless damaged & they're not even a normal parts stock.
    Just need to get a suitable socket for the drive shaft nut and the bearing to hub bolts then.
  1. Wheel bearing ids+
    By the hen in forum Suspension, Wheels & Brakes
    Last Post: 20th August 2012, 14:32
  2. Wheel bearing ?
    By THE ROBO 1 in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2011, 22:21
  3. Think i need new wheel bearing
    By parsco in forum Handling & Braking
    Last Post: 10th December 2008, 14:27
