Thread: 3.0 v6 brake performance
    Belfast
    Default 3.0 v6 brake performance
    the brakes on my estate have always felt a little, lets say, under sized and dont exactly fill me with much confidence.
    I have no idea what type/brand of discs and pads are on there but I think i'll change them to see if it makes any difference
    anyone any suggestions on a good type to use?
    also, is there a how2 for changine the break fluid on this 3.0 v6 cdti lump? (it hasnt been done in at least 40k ), and again, any recommendations on fluid brand to use - is there any significant difference?
    The brakes on the 3.0 V6 CDTI tend to lose efficiency in the final 25%
    I tend to replace once they are down to this point
    VX parts will do fine
    The front pads are about £60, the rear pads are about £35
    The pad and disc kits (front or rear) are about £90
    Brake fluid replacement should be done every two years, irrespective of mileage
    [QUOTE=a18nmk;1493058]the brakes on my estate have always felt a little, lets say, under sized and dont exactly fill me with much confidence.
    also, is there a how2 for changine the break fluid on this 3.0 v6 cdti lump? (it hasnt been done in at least 40k ), and again, any recommendations on fluid brand to use - is there any significant difference?[/QUOTE]
    its the same as bleeding any brake system , you just have to keep doing it until clean fluid comes through
    always good to remove some of the old fluid from the resevoir and top up with new before starting
    any dot 4 brake fluid will surfice , make sure its from a new sealed container though so you dont use fluid that has water ingress in it
    Regular Member HARRY SRI's Avatar
    liverpool
    they are 314mm discs put police spec pads on it,you will get them from LMF.
  2. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  3. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  4. Which performance front brake pads?
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 14:22
  5. Performance box Measure your cars performance..
    By Big-Pete in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2007, 18:09
