Thread: gear stick
    exeter
    Default gear stick
    i have a vec c 20dti . can anyone please tell me how 2 take out the gear stick so i can put the right one back in as some muppet has hack off the orginal gear knob .
    Sodding Typical on Sea
    Unhook the gaiter from the console and lift out the way,
    Unbolt the cradle,
    (4 bolts onto the tunnel)
    Disconnect the cables
    Replace is a reverse of the above
    exeter
    thanks for that i will give it ago . it sounds easy
    exeter
    my manual says to remove the centre console ? do i have tooor what ?.
    Full Member
    South West
    Is if just the stick assembly you want to replace, or the complete cage etc?
    If its just the stick assembly, then its just the cradle, and popping off the bottom ball joint.
    Took me about 15 mins all told. I used a long screwdriver to pop the ball off.
    Rgds
    Aidi
    exeter
    i just got the gear stick from ebay and its reverse is to the left and top . i need one with the reverse down and right is there anything i can do ? and before you say i did ask them the question .
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    thats for a cdti mate thats the wrong one
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by reeseandellie View Post
    Send It Back
    exeter
    someone has broke the cup that the gear stick pin sits in . and vaux told me you can't buy it in pieces and it will cost £156 plus vat . for a new cradle and stick
  1. Gear stick
    By Puffalo bill in forum Bodywork & Interior
    Last Post: 4th January 2012, 18:34
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. any one got an old gear stick ?
    By Lump in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2009, 11:41
  4. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
vectra c gearstuck spring broke site:www.vectra-c.com
