Thread: Emissions light
    Regular Member iain.condliffe's Avatar
    Feb 2007
    Cheshire
    Default Emissions light
    Hi all,
    My emissions light has recently come on. It has given the fault code p0400 5a which is EGR flow insufficient. Prior to this the car failed it's mot on smoke, it got through with a new fuel filter and a tin of 44k additive.
    I have cleared this and unsurprisingly it came on again about 24 hours later. So, am I right in thinking the following:
    The EGR valve needs cleaning with carb cleaner as per the how 2s and the gasket replacing with the fiat type.
    Or do I replace the valve outright?
    The car is a cdti 120 and has done 31000 miles.
    And to top it off the drivers dip beam went too!
    Thanks in advance.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I think you have answered your own question, clean it then replace if that doesn't work
    Doncaster
    Default Exhaust gas recirculation flow insufficent
    hi i have the same code on my car but i have cleaned it but i have a tuning box on so any help would be appreciated
    Jul 2010
    kent
    how long after cleaning the egr valve should the engine gas light go out?
    Feb 2011
    Selby
    It'll go out when you clear the fault code Then assuming flow is fine, it won't log the fault. I'm not sure if this code clears itself after so many starts or whether it's a permanent one that needs to be cleared with a code reader.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    try this also
    i have couple of threads on this
    check the egr solenoid
    http://www.vectra-c.com/forum/showth...ult-code-P2279
    post 8
    also post 3 below
    http://www.vectra-c.com/forum/showth...2279-grrrrrrrr
    Quote Originally Posted by rich r View Post
    The Emissions Warning Light is a reactive warning
    Once activated it puts the engine into Safe Mode which applies for 12 hours, the light then stays on for three more engine starts
    The next time it applies for 24 hours
    The next time it applies for 48 hours
    The cycle then repeats
    Regular Member Ozyboyross's Avatar
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Engine : 1.9 CDTi 150
    Mileage : 90k
    I doubt it.... I've had my egr unplugged for about a month now and I've never had limp mode and the emissions light stays on continually?
    So I can't see why it would cycle through or throw up limp mode?
    Quote Originally Posted by Ozyboyross View Post
    This is with the EGR Valve still connected
    On the Y30DT engine it is a nightmare to access
    I eventually realised the cycle being applied, presumably to make it more obvious to the owner / driver
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Mileage : 90k
    Ah I see lol I was just explaining how its reacted on my car
    Wish I had a 3.0 cdti though lol
  1. Emissions light
    By shuggler in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2012, 19:16
  2. emissions light
    By trickster75 in forum Engine & Drivetrain
    Last Post: 19th May 2011, 21:10
  3. Emissions Light
    By battle84555 in forum Engine & Drivetrain
    Last Post: 20th February 2011, 19:56
  4. Emissions Light
    By Frp01 in forum Engine & Drivetrain
    Last Post: 23rd March 2010, 09:31
  5. Emissions Light
    By BigKev1970 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th September 2007, 22:16
vauxhall vectra 1.9 cdti sri emissions light is staying on
