Results 1 to 2 of 2
Thread: Monroe STD shocks on 3.0 cdti ?????
    Feb 2011
    Norwich
    Default Monroe STD shocks on 3.0 cdti ?????
    Hi all, this is the 1st time that I have used a forum. I have a 07 Signum 3.0 V6 cdti. I have just put a pair of Monroe STD shocks on the rear. £67 instead nearly £500 for the Vx genuine ones !! 20mm longer but can't see any difference in the car height ! The ride is a bit firmer and holds the corners a bit tighter!! So far so good. But I had a n/s/f wheel bearing fitted at the same time. But the new bearing was faulty ( I was told it was from a bad batch) ABS sensor faulty (open Circuit) When the faulty one was removed (800 miles and 10 days later the grease was oozing out all over sensor!! New Bearing hub fitted, ABS light out, all is well again !! But the ABS does not work like it should ?? when breaking on dry good roads ABS cuts in for 2 seconds and then ok. Could this be any thing to do with the rear Monroe Shocks as I have been told by my fitter who spoke to Vauxhall on the phone ?????? I hope somebody can HELP ?????
    Feb 2011
    Norwich
    All is fixed now 3rd New Wheel Bearing hub fitted !! ABS ok, Speedo Ok, Monroe Shocks ok.
  1. Rear Shocks for SRi CDTi...
    By Dan_BlackSRi in forum Handling & Braking
    Last Post: 29th August 2012, 15:40
  2. V6 cdti sri front shocks
    By smitd004 in forum Suspension, Wheels & Brakes
    Last Post: 30th November 2011, 07:13
  3. CDTi 150 SRi Springs & Shocks
    By Telly Addict in forum Parts for sale
    Last Post: 23rd February 2011, 19:15
  4. Uprated Monroe Shocks
    By lancaster in forum Suspension, Wheels & Brakes
    Last Post: 22nd January 2009, 13:00
  5. CDTI 150 SRI Shocks + Shuddering
    By terrym2002uk in forum Suspension, Wheels & Brakes
    Last Post: 7th April 2008, 20:11
